Old 07-08-2016, 02:17 AM   #1
First post. Looking for info
I'm looking for any info on an older (2001) 30rlfs 5th wheel. Specifically, the height of the pin to see if it will work with my truck. The trailer is out of state so just looking for general info. Google didn't return much info.
Thank you
RichardAK is offline   Reply With Quote
Old 07-08-2016, 06:05 AM   #2
Thank you
I recently traded in my 1998 Forest River Wildwood M24RLS and the hitch pin height is adjustable. Here is a u-tube video of a 2002 rlfs that I found online
ShermanD is offline   Reply With Quote
Old 07-08-2016, 12:11 PM   #3
Old 07-10-2016, 08:09 AM   #4
Old Member
The truck and trailer combo will probably work. Several variables. The pin on the trailer is usually adjustable and most of the hitches in the truck are adjustable. The problem that may arise is the how level the trailer is once hooked up. You would like to get it as level as possible while towing. Raising the hitch to get lots of clearance may cause the trailer to ride nose high.
A trailer of this vintage will probably have springs that are sagging and that won't help. Fortunately, rebuilding the undercarriage is relatively inexpensive.,
Cool Canuck is offline   Reply With Quote
Old 07-11-2016, 02:26 AM   #5
Thank you. That was my concern. I wanted to the trailer to ride pretty level and it is hard to determine from pictures how much clearance there would be. I thought that someone on this forum may have one of these older models. The one that I am considering is down in WA and I'm in AK. And the owner is up here as well.
