Old 04-28-2016, 01:57 PM   #1
Flapper seal in "Black Tank" CC 29RE
When my spouse was cleaning the toilet bowl with a brush the flapper seal came off and fell down into the black water tank......Has not been a continuous problem but on a couple of occasions TP must get caught up at the drain opening (with seal) and nearly stops flow. Any suggestions on how to "fish" out the seal.......stiff wire with a hook up drain pipe?????
Jim in Halifax is offline   Reply With Quote
Old 04-28-2016, 02:17 PM   #2
A wire with a hook might work provided it is still in the pipe that connects the toilet to the tank. I have a set of 'Chinese Fingers' on a flexible shaft that works well to fish stuff out of hard to reach places.
Once it gets into the tank... all bets are off.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 04-28-2016, 02:29 PM   #3
clr
I have a inspection camera that came with tools. One of the tools is a hook type that one could use to pull the seal back up the waste pipe. The flexible cable for my unit is about 3 feet long. Has a built in light also so you can see in the dark places. Just one more idea here of a way to get the seal out. BTW the cleaning procedure for the toilet says nothing about a household brush use due to that little seal. Good luck with the training of the wife here LOL.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 07-16-2016, 09:29 AM   #4
DK-in-SC's Avatar
Were you ever able to fish it out? My seal went down into the black tank yesterday. Not looking forward to this project. Also, how hard was it to install a new seal?
I live with fear every day, and sometimes she lets me go fishing.
2015 Shamrock 23IKSS
2008 Ford Expedition EL
DH-DW-D3K-DMTTSAP
DK-in-SC is offline   Reply With Quote
Old 07-16-2016, 10:06 AM   #5
Seal
Still there....Has not created any problems to date!!! Keeping fingers crossed!!!!! J
Old 07-16-2016, 10:46 AM   #6
DK-in-SC's Avatar
Did you replace the seal yourself, or did your dealer fix it for you? How hard was it?
DH-DW-D3K-DMTTSAP
Old 07-16-2016, 10:59 AM   #7
Yes I did.....Turn off water and I put some paper in hole in case I dropped new seal....My wife held flapper open and I installed new seal.....Just feel that seal is set on flapper!!! It would be easier to remove toilet and install seal BUT I was lazy!!!!!! J
black, black tank, tank
