Old 08-07-2016, 05:58 PM   #1
Fresh Water Tank Sanitizing
The manual says to sanitize the fresh water tank by adding bleach through the fresh water connection. Says to just poor it in. Problem is there is a 90 behind the panel and the tubing goes up. The bleach would need to be under pressure to get it in there. Is there another way to poor bleach into a 2016 Silverback 31RK
Henry16415 is offline   Reply With Quote
Old 08-07-2016, 07:06 PM   #2
fonzie's Avatar
Pour bleach into garden hose, hook up to trailer and fill fresh water tank.....
Fonzie
Old 08-07-2016, 07:08 PM   #3
Ford Idaho's Avatar
X2
Old 08-08-2016, 09:21 AM   #4
fonzie's Avatar
On my unit I have an overflow tube but I have gravity feed inlet to fresh water tank....you should have an overflow and when filling with pressure from hose you should go slow to prevent what happen.....hope others with similar unit will chime in.
Fonzie
Old 08-09-2016, 11:08 AM   #5
Global Nomad
Scheinin's Avatar
[QUOTE=Henry16415;1283275]The manual says to sanitize the fresh water tank by adding bleach through the fresh water connection.
On my 2016 36CKTS, there is a tube to winterize. I would think, if you have the same thing, just add bleach through there.
Where did you get a manual? None came with mine, and I sure would like to have one.
Steven J. Scheinin
2015 RAM 3500 4X4
6.7L CTD Dually pulling a
2016 Cedar Creek 36CKTS (Center Kitchen Three Slides)
Scheinin is offline   Reply With Quote
Old 08-16-2016, 01:24 PM   #6
U can download manuals off of c.c website but don't expect much info from them. One manual covers multiple models with varying options.
cody1884 is offline   Reply With Quote
Old 08-16-2016, 02:16 PM   #7
Originally Posted by Ford Idaho View Post
X2
Yup. Easy peasy.
I dump bleach in the spigot end. That way the hose gets a taster.
Sent from my iPhone using Tapatalk
325BH is offline   Reply With Quote
Old 08-16-2016, 04:38 PM   #8
SilverbackMel's Avatar
You can also use an inexpensive turkey Baster available at a Dollar Store. Just squirt into a hose end while attached to fresh water intake.
BE SURE YOU ARE ON GRAVITY FEED! 😂
SilverbackMel is offline   Reply With Quote
Old 08-21-2016, 02:12 PM   #9
I buy the gel bleach. It comes in a squirt bottle.
Brentf is offline   Reply With Quote
fresh water, tank, water, water tank
