Old 05-10-2019, 07:54 PM   #1
Fridge not switching to AC
I am thinking my fridge is not switching to AC in auto mode. Both lights are on as it shows in the picture. I plugged in a hair dryer to check the plug and it worked. So thats not the problem. Any other ideas what to look for?Click image for larger version
jmcclocklin is offline   Reply With Quote
Old 05-10-2019, 08:07 PM   #2
Indy500's Avatar
Originally Posted by jmcclocklin View Post
I am thinking my fridge is not switching to AC in auto mode. Both lights are on as it shows in the picture. I plugged in a hair dryer to check the plug and it worked. So thats not the problem. Any other ideas what to look for?Attachment 204265
Turn off your gas , then see what happens,
Indy500 is online now   Reply With Quote
Old 05-10-2019, 08:11 PM   #3
Check the glass fuse on the control board on the back of the fridge. I had the same issue and my read out looked the same.
Turns out the fuse holder tabs were loose and not holding the glass fuse tightly. It heated up (from poor connection) and melted the solder inside the fuse.
Looking at the fuse, it looked good but testing with a meter, it showed open.
I replaced the fuse and all was well.
Mine quit at some point during an auto switch from AC to LP. We left to go on a trip and the fridge didn't work on AC when we arrived and plugged back in to shore power.
I checked many automotive stores for a fuse but none fit. (It's short) I finally found one at CW. (Camping World)
Thankfully it continued to work on LP while searching for a replacement fuse.
I bent the fuse holder tabs tighter together when replacing the fuse and it has never happened again in 2 years.
BTW... there is a 5 amp automotive style fuse on the control board as well. That is for the 12v side of the controls.
Days Camped: '16=46 '17=30 '18=51 '19=18
Old 05-10-2019, 08:32 PM   #4
bubbles's Avatar
Ask for a 2AG fuse in the amperage needed. 3AG is the typical length fuse we're used to seeing.
Old 05-10-2019, 08:40 PM   #5
Turned off gas and started flashing LP
Old 05-11-2019, 04:55 PM   #6
Could also be electric heating element is bad.
Only way to tell is disconnect power from element, connect a meter to element and check for ohm reading to see it is any good. Then check for 120 volts at plug feeding element once power is turned back on and fridge is calling for a. Once it switches to LP, you'll have to recycle power to test again.
Hope this makes since and helps.
wvram is online now   Reply With Quote
Old 05-14-2019, 08:41 AM   #7
Thanks for your help the fuse was the problem. My last question is I cant find a 5 amp fuse but I do have a 7.5 amp fuse. Will it be ok to use it instead of a 5amp?
Old 05-14-2019, 09:08 AM   #8
Glad you solved the issue.
I too had trouble finding a fuse and the earlier suggestion of requesting a 2AG fuse didn't help as it seems this fuse is something of it's own.
I found a fuse that fit at CW (also 7.5 amp) and used that until I found some on the 'net that were the same number/amperage as the one in there from original.
I'll look back and see if I can find where I ordered from and edit if I do.
Old 05-14-2019, 10:36 AM   #9
bubbles's Avatar
Guessed at the 2ag size duh. Google 1 aga 5 amp fuse and see if this is the right size.
Old 05-14-2019, 11:07 AM   #10
Head Rambler
If I remember right those are 5mm X 20mm fuses. Smaller diameter than standard AGA fuses.
Gotta go campin!
fridge, switch
