Old 03-17-2014, 10:25 PM   #21
mlatter's Avatar
Originally Posted by OL Creeker View Post
Did you know there's a fail safe in the water heater? Yep. Ya can't burn the element even if there's no water in the tank, per the factory.
No I did not! My old 5th wheel had a switch on the control panel to put 110v to the water heater - you had to intentionally turn it on. My current one has it on by default, kind of. There is a switch outside at the water heater, but I usually turn it off and on with the panel breaker switch. When I picked up my unit and got it home and plugged in, I didn't know the water heater was on. I started messing with filling the water tank, etc. and I finally realized that the tank heater was on. I was wondering why it didn't burn out the element without water in there. Now I know - thanks!
2014 Cedar Creek 36CKTS Explorer
Xantrex Freedom SW3012 inverter/charger
2009 Silverado 2500HD Duramax Crew Cab short box
Demco Glide Ride pin box
Demco Hijacker Autoslide 18K hitch
mlatter is offline   Reply With Quote
Old 03-18-2014, 08:32 AM   #22
Brother Les's Avatar
Could someone show me in the 'paperwork'/ Manuel where it states that electric water heater has a fail save switch if there is no water?
Brother Les
Old 03-18-2014, 09:43 AM   #23
OL Creeker's Avatar
Fail safe
While at the factory, we were told after asking why the elect switch wasn't in the coach, that suburban moved it because lookers were burning up the elements. They would turn on items just because. They went one step further and put a sensor in to prevent burning up the element in the event there was no water in the tank. One person on the forum said he had that happen to him - and it didn't burn the element.
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
OL Creeker is offline   Reply With Quote
Old 03-18-2014, 03:25 PM   #24
Former Full Timer
Duckogram's Avatar
The suburban water heaters have an external switch only. The circuit breaker is not a switch and should not generally be used as one.
The next goodie you will find if you look at the wiring diagram is the Hi Limit/ECO (electric cut off) switch. This safety item has been in use for a long time. In the event the thermostat fails, this gem cuts the power to the heating element. It is designed to prevent catastrophic failure due to overheat. Since it derives it's temperature sensing from the surface of the tank, I don't think it would qualify as a fail safe to prevent element burn out. Following the hi limit/eco is the thermostat. It also derives it's temp sensing from the tank. There are no other switches, sensors or gizmos associated with the 110v side of the water heater.
Now with that being clear as day. This issue is way off topic and should end here.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 03-18-2014, 03:35 PM   #25
fonzie's Avatar
pavetim are you still there?
Fonzie
Old 03-18-2014, 09:04 PM   #26
OL Creeker's Avatar
Suburban water heaters have TWO switches. One, electric, external. The second, in the panel of switches above the broom closet, is the switch for the LP gas. I agree, the circuit breaker should only be used for maint purposes.
Duramax/Allison
Old 03-18-2014, 09:13 PM   #27
TURBS's Avatar
Not true......
My suburban has three.
One outside
Two inside.
Factory installed
TURBS
Sabre owners united!
Old 03-18-2014, 09:16 PM   #28
VinceU's Avatar
Nice feature, somewhat rare?
Old 03-20-2014, 05:35 PM   #29
Grateful's Avatar
Batteries for Fridge
Hello, I would like to ask further about a bank of batteries for the fridge. We are now owners of the Columbus 320 RS. It has a residential fridge and 1500w inverter with one 12v battery. Our goal is to have fridge powered up for two days of dry camping at a time. I have read about two and four 6volt battery configurations (parallel). What are your thoughts to achieve our goal?
Thanks in advance,
Grateful
Columbus 320RS
Chevy 3500 HD CCSB
Dmax & Allison, SRW
Anderson 5th Wheel Hitch
Grateful is offline   Reply With Quote
Old 03-20-2014, 05:42 PM   #30
Originally Posted by bikendan View Post
pavetim, did you get an optional residential fridge/freezer? it would run off an inverter and requires a huge bank of batteries, if not on shore power.
if not, then your fridge/freezer is powered by either propane or 110v AC electric power.
are you saying that the dealer didn't show you how to run it on propane, during the PDI?
Didn't know they made a residential that would run on propane.
All I've heard are rv frig on either 12v/propane/110v/propane or 12v/propane or propane only.
battery, fridge
