Old 03-14-2014, 08:52 PM   #1
fridge on battery?
Can you run the fridge on battery? My daarn genny is only putting out 80v so wont run the fridge but does seem to charge battery.
pavetim is offline   Reply With Quote
Old 03-14-2014, 08:58 PM   #2
Boss Hoss's Avatar
As far as I know-they only run on Propane or 110 Volt power.If you have the correct inverter(From 12 volt to 110)-and a power source to run it-you should be OK.Check the power specs to make sure you don't burn anything up.
2013 Palomino 30ft. of Pure Bliss at 5400#-and then we have this 14 ft.Sea Eagle that I tote around for my wife and son.Michigan State Parks are The Best !:thumbsup
Boss Hoss is offline   Reply With Quote
Old 03-14-2014, 08:59 PM   #3
HONDAMAN174's Avatar
Will suck down the battery faster than it can be recharged. Use propane.
Just glad to get away
Old 03-14-2014, 09:03 PM   #4
davel1971's Avatar
if your generator is only putting out 80 volts, you better not use it to power anything. You are just asking to replace something, other than the generator.
David & Lynn
Old 03-14-2014, 09:10 PM   #5
How do you run fridge on propane, I dint see switch anywhere. Ihave a 36ckts
Old 03-14-2014, 09:13 PM   #6
fonzie's Avatar
Make sure your battery is well charged, turn propane on and select "gas" on fridge. It should light up if all ok. If you have a residential fridge then it will not operate on propane, electric only.
Do you have this option:
Optional 18 cu. ft. stainless steel electric
residential refrigerator with invertor
If yes, then it is only electric.
Fonzie
Old 03-14-2014, 09:57 PM   #7
CZNEDY's Avatar
If you push the auto button on your fridge, it will run on electric (120 Volt AC). If plugged in and gas (if you have the propoane bottel open) when you unplug.
Just remember to turn it off when you are a the gas station
2018 BERKSHIRE 34QS
2004 Jeep Wrangler and a
Cooler full of good ideas
Days Camped, Not Enough
CZNEDY is offline   Reply With Quote
Old 03-14-2014, 10:13 PM   #8
bikendan's Avatar
pavetim, did you get an optional residential fridge/freezer? it would run off an inverter and requires a huge bank of batteries, if not on shore power.
if not, then your fridge/freezer is powered by either propane or 110v AC electric power.
are you saying that the dealer didn't show you how to run it on propane, during the PDI?
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 03-15-2014, 06:58 AM   #9
Campingnut's Avatar
I think he has the residential fridge.
You can run the fridge on just the batteries but I do not think you will get much more then one day that way.
Tim and Bev
2013 Cedar Creek 34RLSA, Magnum 2800w inverter, 560w of solar.
2015 F-350
Campingnut is offline   Reply With Quote
Old 03-15-2014, 07:02 AM   #10
Ford Idaho's Avatar
Then he does need a bigger "genny".
battery, fridge
