Old 08-24-2016, 12:17 PM   #1
Question Galley and bath tanks
New 38ck owner--posted awhile back. New subject. While in the shower noticed water starting to get deeper. Checked little lights in panel by the door and saw that one tank showed full, also noticed the kitchen sink was burping. Went out to drain bath tank not much water, opened galley tank valve and plenty of water. It appears the shower and the kitchen sink both drain into the same tank. Is this how other owners of a 2017 38ck have this to be?? I recon the washer, which I don't have, must drain into the bath tank. Thanks for any replies. Also should mention this is first trip with this trailer since recent purchase---sure do like it so far.
sand38 is offline   Reply With Quote
Old 08-24-2016, 04:12 PM   #2
Rest and Relax's Avatar
If this is a new to you trailer it may be that the wires on the back of the indicator are crossed ie. Kitchen hooked to bath and bath to kitchen?
Mark And Libby
2011 F-350 4X4 Super Crew
2015 Cedar Creek 38FB2
Brampton ON.
Rest and Relax is offline   Reply With Quote
Old 08-24-2016, 04:51 PM   #3
Rest and Relax--thought about wires crossed and/or drain valves marked incorrectly. The shower had been used 4 times and the kitchen sink used quite a bit more and the bath tank had practically no water while the galley was full. This why I suspect the shower and the kitchen sink both drain into the galley tank. Thanks for the response.
Old 08-24-2016, 05:08 PM   #4
Hutch333id's Avatar
It is the same on my 2014 38FL. The shower drains in to the galley tank, which on my display board is tank # 2. The washing machine (if I had one) would drain in to the tank #1 which is the bathroom hand sink. I think it just helps balance out which tank fills in the advent of you having the washing machine.
Richard & Diane
2014 Cedar Creek 38FL
2016 F350 Lariat CC DRW
Retired Metropolitan Police (UK)
Hutch333id is offline   Reply With Quote
Old 08-24-2016, 08:48 PM   #5
I have a 38 CK. You guys have figured the tanks correctly. I have and love the washer/dryer. It shares the bathroom sink tank. The grey water tanks are on different levels so they can't be cross balanced either. When dry camping, before I had the washer, I closed the blackwater tank , opened the two greys and used an external shutoff. The lower tank filled first. Wasn't too helpful.
William & Sara
2012 Silverado 2500 HD DA
2014 Cedar Creek 38CK
Sterlingsilver is offline   Reply With Quote
Old 08-25-2016, 01:40 PM   #6
On my MH the galley and shower are on one side of the coach and toilet and lav are on the other. The galley and shower go to galley tank and toilet and lav go to black tank. I read that they do that partly to add a little estra water to the black tank which makes dumping go a little better.
markb422 is offline   Reply With Quote
Old 08-25-2016, 02:02 PM   #7
DKRITTER's Avatar
We added a twist on valve to the end of the black ridgid sewer line and if we are dry camping or don't have full hookup's. We close the twiston valve and open both the galley and bath tanks and can go a week w/o having to drain comfortably.
Another benefit of the twiston is if you have a slight leak for whatever reason keep it closed and you won't get a bath of "stuff" when you pull the cap off to hookup the sewer hose.
2015 Ford F350 CC SRW LB 4X4
2016 Cedar Creek 36CKTS (My Last FR Product)
20,000 LB Reese GooseBox Hitch
DKRITTER is offline   Reply With Quote
Old 08-25-2016, 05:07 PM   #8
Added one my new 36CKTS on my way home from the dealer. Should be standard equipment on a new rig.
2015 Chev Silverado 3500 dually D/A
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
Old 08-25-2016, 05:49 PM   #9
D K Ritter and GOTTOYS--Good info. Thanks for the idea. DKRitter is the goose box working out O K? Put one on this new rig before first trip. Me thinks it will be O K. May have to adjust the air a time or two till it is right.
Old 08-25-2016, 06:04 PM   #10
DKRITTER's Avatar
I love the GooseBox. I had one issue when it was new, it would need air every time we stopped. I called Reese and they weren't sure but I did notice it wasn't easy to put air into so I replaced the valve core and that was all it needed.
I put 60PSI in when I air it up and it settles in at somewhere just above 50. It has a popoff valve so I don't worry about it.
I put airbags on the F350 and air them to 12PSI and the ride is great.
We weighed the truck and trailer last christmas and had about 2 weeks worth of stuff in it so I would say that was a good weight for us. The whole trailer weighed 15,000lbs, the hitch was about 3K and the axles were about 12K.
A big PS check the torque on all the bolts, everyone of mine were way low my guess is they used an impact.
tank
