Old 01-15-2015, 12:08 PM   #1
Galley and gray water valves
I'm new to fifth wheels and I cannot figure out where the two grey water valves are on my Cedar Creek. I have the 2005 Cedar Creek 37RDQS. My galley is currently showing full and I want to pipe it out to my plants since I use all biodegradable and I don't put food down it. Hopefully someone here can tell me what I need to do or where I can find the information, I've been spending a lot of time looking and I'm not finding anything helpful. Thank you!
Imasloane is offline   Reply With Quote
Old 01-15-2015, 12:21 PM   #2
Zoo1392's Avatar
Left side,or right side looking Fwd to back, BIG access door right side of the compartment, the handles are next to the water hookup. be sure you hooked up you poo hose first before pulling those. Flush (open) Black first, Gray kitchen second and Bath valve last.
Don & Rebecca
living can be broken down into two elements
Define the essentials
Eliminate the rest
Zoo1392 is offline   Reply With Quote
Old 01-30-2015, 12:27 PM   #3
Dump Handles
Just found out yesterday that the lables for my grey tanks are marked wrong!!!!! Reversed!!! How could that happen at cc--FR?
Jim in Halifax is offline   Reply With Quote
Old 01-30-2015, 10:05 PM   #4
mlatter's Avatar
My handles were labeled wrong as well. Had a grey and the black tank mixed up.
2014 Cedar Creek 36CKTS Explorer
Xantrex Freedom SW3012 inverter/charger
2019 F350 Platinum CC, PSD, 4X4, long box, SRW
Demco Glide Ride pin box
Demco Hijacker UMS 21K hitch
mlatter is offline   Reply With Quote
Old 01-31-2015, 12:19 AM   #5
SilverbackMel's Avatar
Sounds like crap to me!! Maybe they sensed you are a biodegradable person and you infringed on the Amish tradition and this is your payback!!
Or, maybe not 😬
SilverbackMel is offline   Reply With Quote
Old 02-07-2015, 05:32 PM   #6
Our black water cable to the valve broke any idea how to replace it.
Silverback Iowan is offline   Reply With Quote
Old 02-07-2015, 05:54 PM   #7
Broken Cable...Where???????????
First you have to find out where it broke.....At the tank.....Sometimes they have a connector to join two cables...Did it come apart.....May have to remove bottom panels to investigate....J
Old 02-07-2015, 07:35 PM   #8
Broke at the end of the rod. He got it apart there. Hope to just fix it there some way if he can get a new handle and tie it together someway.
water, valve
