Old 11-12-2013, 10:35 AM   #31
Old Member
mikey's Avatar
Send a message via Skype™ to mikey
Mine is 13'4" @ the hi point on BR AC. Not had a problem in last 22000 miles. Might be luck but also could be result of superior planning on DWs part (Motor Carrier Atlas has a section listing every low clearence along a particular route w/ specific location, all hi lighted routes are clear to 13' 8" according to OTR truckers I spoke with)
Also, I don't subscribe to using lift kits or big (35" or greater) tires on a tow vehicle. Guess there might be more n one meaning to tow vehicle as in "toy" truck? 4x4 will raise the hitch height which translates to a taller trailer height!
Drivin, Miss Daisey & the boss, Toppi
2018 Berkshire XL40B-380, SFE=244
mikey is offline   Reply With Quote
Old 11-19-2013, 06:56 PM   #32
greysailor's Avatar
No lift kit or other aftermarket items on my truck, but yes, the 4X4 does add a couple inches to bed height.
After discussions with dealer, it seems that the Dometic "Penguin Low Profile" A/C units are no longer 9 1/2" tall due to a recent production design change....My B/R A/C has the Penguin model numbers, but it is 11" tall. I guess they should have installed something like a Coleman Mach8 which is only 8" tall....... Waiting to hear if it is compatable with ducts/thermostat wiring...
Took another measurement with the RV unhitched and perfectly level (which is the recommended towing height) and I am 13' 7" to the top of B/R A/C. This would have required a permit in Indiana (and most other states) when it left the factory...... Waiting for return call from factory now as to how to proceed....
2014 Cedar Creek 34RLSA
Blessing, Texas
greysailor is offline   Reply With Quote
Old 11-20-2013, 06:51 AM   #33
Dodge Guy's Avatar
Stay away from here then!!!
11 FOOT 8
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 11-20-2013, 11:11 AM   #34
racer4's Avatar
greysailor,
Do you have a Penguin or a Penguin II?
Dometic claims the Penguin II is "under 10 inches high".
Products - Dometic
The various Penguin II model numbers are in this brochure:
http://www.dometic.com/2664aef6-0859...0fecbb1a.fodoc
If your Penguin is 11" and the Penguin II really is less than 10", you can gain 1 inch and get down to 13'6".
It doesn't make sense that CC would build one that exceeds 13'6" when level.
Good luck and keep us posted.
Chris and Pat
2016 Ram 3500 Cummins Aisin Dually, 4.10 axle, Auto Flex Air Ride Rear Suspension
2017 Cedar Creek 36CKTS, Disc Brakes
racer4 is offline   Reply With Quote
Old 11-20-2013, 11:29 AM   #35
greysailor's Avatar
Originally Posted by racer4 View Post
greysailor,
I have a Penguin II.....but I can say for sure that it sits 11" above the roof. They must have not taken the mounting gasket into consideration in their spec sheet.... Far as I can see, the Coleman Mach8 is the only A/C that will lower my overall height.
Blessing, Texas
