Old 10-30-2013, 05:12 PM   #1
greysailor's Avatar
Geeeezzzzzz! 13' 8" Tall !!!
Finally got through fixing things on the new CC34RLSA that were missed during PDI and doing some improvements, and thought I'd measure the beast before first shakedown trip. The top of the B/R AC is 13' 8" when sitting on my F350 4X4. Not happy with that....will require much closer route planning than the old 40' diesel pusher MH. I guess the Trailair pin box, 4X4 truck with factory 20" wheels all add up to "overpass stress".
2014 Cedar Creek 34RLSA
Blessing, Texas
greysailor is offline   Reply With Quote
Old 10-30-2013, 05:26 PM   #2
Always Learning
I keep meaning to measure mine. When I get it back, I'll definitely measure it at the storage lot (the closest thing to level around me).
Old 10-30-2013, 05:40 PM   #3
Certified Curmudgeon
Indeed it will. mine is 13'4" on a F350 2x4 with the 17" Aluminum's.
Some overpasses on I-95 in New England are 13'7". They looked lower but we still have both A/C's.
Mike Dropped
Old 10-30-2013, 05:59 PM   #4
Professional Curmudgeon
wrvond's Avatar
I could never be that brave. Or that confident in my measuring abilities...
2022 Cougar Half Ton 24RDS fifth wheel
2014 Coachmen Catalina 253RKS (sold)
2017 F350 6.7L DRW CC LB 4x4 Lariat
wrvond is offline   Reply With Quote
Old 10-30-2013, 06:03 PM   #5
iceblaze580's Avatar
That's quite a squeeze
iceblaze580 is offline   Reply With Quote
Old 10-30-2013, 06:17 PM   #6
AquaMan's Avatar
Had mine measured in Goshen, when LIppert reps didn't believe I was 13'-4" sitting level. Proved them wrong.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 10-30-2013, 06:22 PM   #7
How level is your CC when hooked up to tow?
My 34RLSA measures just over 13' at the highest point when hooked up to tow and the trailer rides a little nose high. But we don't have the BR AC.
How much height does the BR AC add?
2014 CC 34RLSA
2013 RAM 3500 Laramie CC SB 4x4 CTD
sidney is offline   Reply With Quote
Old 10-30-2013, 06:26 PM   #8
Firefighter969's Avatar
I am 13'5 to the top of the master bedroom A/C
2000 F250 Superduty CC LB 7.3 4x4
2013 344QB Wildcat
Nights camped 2014 ( 15)
Nights Camped 2015 ( 4 )
Firefighter969 is offline   Reply With Quote
Old 10-30-2013, 06:28 PM   #9
Oklahoma Proud
MillerTime's Avatar
Op just for your info dot restricts heights to 13'6", anything above is going to need oversize load permits. (Some states will allow 14-14'6" on interstates w/o an escort).
Honestly I doubt you will ever be checked by dot, but just thought id give you a heads up. Thats frustrating im sure!
Old 10-30-2013, 06:54 PM   #10
greysailor's Avatar
Thanks Miller, but here in TX it's over 14' for a permit load.....still doesn't make me feel better though!
Others:
The B/R AC adds around 8-9" height.
Height was measured on concrete bus barn floor, and 4' level on kitchen floor showed 1/4" high on forward end. I figure that would equate to about an inch high at pin.
Also, I forgot to mention that I opted for the 7K axles and LRG tires...that might have a tiny effect on height....
Blessing, Texas
Old 10-30-2013, 09:06 PM   #11
mlatter's Avatar
That's troubling information, considering I'll be driving through there next week with my rig measured at 13'7". I did find an article that says "State law requires that vehicles not exceed a height of 13 feet 6 inches, and no overpass bridges along I-95 are below that height, according to DOT. Some of the shortest bridges on I-95, however, are only inches higher than that requirement, leaving little room for error."
From here: Low bridges make for dangers on I-95
Are you able to tell me which ones are that height, or point me to a reference?
I may have to drop the air bags down an inch to bring it to the 13'6" legal limit. At least if I'm there, I'll feel safe if there are trucks in front of me.
2014 Cedar Creek 36CKTS Explorer
Xantrex Freedom SW3012 inverter/charger
2019 F350 Platinum CC, PSD, 4X4, long box, SRW
Demco Glide Ride pin box
Demco Hijacker UMS 21K hitch
mlatter is offline   Reply With Quote
Old 10-30-2013, 09:23 PM   #12
In this area of VA if you're over 13'6" the over height fixed electronic beams will be set off and all sorts of alarms and lights will let you know!! It's to protect our tunnels and bridges. The Chesapeake bay bridge tunnel is the best example CBBT.com
John & Susan, Olivia the dachshund
2011 Georgetown 337DS
2003 Dodge Dakota
Hampton Roads VA
2016 174 Days camping, 2017 66 days 2018 24 days 2019 48 days 2020 25 days 2021 6
mogman is offline   Reply With Quote
Old 10-30-2013, 09:42 PM   #13
mlatter's Avatar
Quoting my own question here... I had an app on my iphone called Allstays Camp and RV that I bought a while ago that has a low clearances feature. I zoomed in and followed the i95 from Houlton to Boston and there are two low points, that are listed at 13'6", both on the stretch of highway in Maine between Portland and Portsmouth NH. Sounds scary, but I feel a little better now because I went under them both earlier this summer before I swapped my full-sized bedroom a/c for a proper low profile unit, and also before I got my new air bags. I'd say the air bags added about 2" in height, but the new a/c subtracted about 3" so I am actually 1" shorter now than when I went through. I am guessing I was pretty close considering my actual height would have been 13'8".
Old 10-30-2013, 09:59 PM   #14
Sorry, I don't remember which ones but I did have my height alert set at 13' 6" and it never went off. The Maine Turnpike is posted max height of 13' 6". The sign and the specific low clearance points are posted at the Kittery entrance point (toll plaza & weigh station).
If you have a bedroom stereo, don't forget to lower your antenna to the same height as your AC.
Canada is 13'8" in NB.
Mike Dropped
Old 10-30-2013, 10:23 PM   #15
Supplemental Info:
For those who want to claim that they have travelled US-1 from Key West to Calais, the clearance from Calais, ME to St. Steven, NB, CA is 12' 1". But, if you call the nice folks in St. Steven, they will
let you cross there. They stopped traffic
in both direction, moved barricades and escorted us through their inspection area.
If you've seen the new car commercial with the diesel pump panic, we got that reaction crossing the bridge... LOL
Mike Dropped
Old 10-30-2013, 10:45 PM   #16
mlatter's Avatar
That's great, and reminded me of a story from a few years back at that same location. Travelling from NB to Maine, I was travelling with my family in our 35' motorhome towing my jeep, and my father and his friend were behind us in his 35' motorhome, towing my 19' boat. Well, he broke down right at the customs window (it was a starter interlock thing...). Anyway, I pulled into Marden's just up the street, unhooked my jeep, and went back and towed the motorhome + the boat back to the Marden's parking lot where we eventually made the repair. Pretty interesting looks I got towing a motorhome... that was towing a boat, with a jeep!
Old 10-30-2013, 11:40 PM   #17
13' 6" on my 32RCTS at the front AC, when hooked up to my 2013 F-350
4 X 4 with 20 inch wheels. Maybe 17 inch wheels would have been a better choice buy they are not 3" lower. I have no idea the difference between 17" & 20" wheels when it comes to real height as I believe the side wall height makes up some of the wheel size lose.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 10-31-2013, 10:59 AM   #18
Just asking MillerTime..... But are you sure about that? I thought that DOT rules/regulations apply only to commercially licensed vehicles, but not to POV's.
Boowho??
boowho is offline   Reply With Quote
Old 10-31-2013, 05:31 PM   #19
rattleNsmoke's Avatar
Milford CT, I-95 southbound they placarded the overhead bridge at 13.5"
rattleNsmoke is offline   Reply With Quote
Old 10-31-2013, 06:01 PM   #20
I took 495 to 84 and missed that haircut...
Mike Dropped
