Generator charging our battery...is it possible??
Question for you regarding our 2013 Silverback 29 RE...yes.... we are a newbies with a fifth wheel.. My question... When dry camping and using a generator what do you need to do so that you can charge the battery? We have a Champion 2000...is there anything that you need to shut off/ ie a breaker. If we shut off the converter breaker, the plugs all work. If we turn on the converter breaker....generator says over load. So...is it possible to charge the battery with the generator? It was with our travel trailer. Thank you so much for your time.
We have our 50 amp plug/30 amp plug/15 amp/generator....
Fridge is on gas...running nothing else.
Thoughts?
