Old 09-07-2015, 04:03 PM   #1
toslow's Avatar
Grey water and black
I was wondering on my 34rl if the grey water tank runs into the black tank when i pull the valve open on the grey,
reason i'm asking id the CG we was at on this weekend had no septic. after we showerd and almost filled the grey tank, i was going to pull the valve to see if it would transfer to the black water tank.
haven a blast
toslow is offline   Reply With Quote
Old 09-07-2015, 04:05 PM   #2
Georgia Frog Rally 2018
aceinspp's Avatar
Nope don't work that way. Hope they had a dump station. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 09-07-2015, 04:11 PM   #3
toslow's Avatar
ya they did, I've got a septic buddy that i ran it into and wheeled it to the dump station
thanks
haven a blast
Old 09-07-2015, 04:40 PM   #4
DaveSchwartz's Avatar
Hmmm... if the grey and black tee into the same pipe where you attach your slinky after their individual gate valves then maybe if you left the cap on and pulled both valves they would equalize levels. However, that would make your life a misery when you finally had to open the cap to dump for real (probably not recommended to mix sewage into your grey tank either).
Just a (nasty) thought experiment.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 09-07-2015, 04:45 PM   #5
toslow's Avatar
my cap has it's own valve. as the grey water and black water, plus there is a galley valve farther back on the trailer. might try it next time i get in the situation
haven a blast
Old 09-09-2015, 09:21 AM   #6
Jim34RL's Avatar
Buy an additional gate valve and attach this to your main dump line. This way you can open both gray tank valves and the water level will equalize between them. The only issues with this is that when you dump you will not have the gray water available to clean the black water from the sewer line.
This is what I would suggest to buy. http://www.amazon.com/Valterra-T58-T...=rv+gate+valve
With me that is not a real problem since I use a Flush King connection to allow the sewer line to be clean by water form the water spigot.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 112K+miles
black, grey water, water
