Old 01-17-2014, 07:10 PM   #31
Originally Posted by MillerTime View Post
If you have the companion hitch, then your install shop did not educate you on the proper removal/ install process for proper hitch mounting. The hitch needs to be drawn down to the bed AFTER the lower pin has been engaged. This eliminates any slop and decreases the likeliness of any pin or bolt shearing, or premature wear/ failure. Just trying to keep you safe.
I work in the collision industry and have replaced many of these hitches that were damaged, and have even had to replace my own after I was in a collision pulling a gooseneck trailer.
- many in here can offer proper install method or you can go straight to b&w's website and download, has torq specs and all.
Stay safe!
Sent from my SAMSUNG-SGH-I337 using Forest River Forums mobile app
Well I have to admit you are right, I went to B&W web site and then I watched one installed on you tube and the hitch needs to be tight against the floor of truck. I will fix that tomorrow and later on I may have someone else look at hitch just to make sure it is installed right. I saw some things on you tube that I want to look at, I want to put a new pin box on 30RL this year, not me of course, someone else thats done it before.
spock123 is online now   Reply With Quote
