Old 10-09-2016, 08:30 PM   #1
Heat Pump Upgrade for Main A/C Unit
I'm not a big fan of heat pumps but wanted to hear how folks that got the upgrade like the heat pump. We usually carry a couple of electric space heaters but since we are about to order a CC wanted to know if we should get this option. Think it is between $300--400 for the upgrade.
2016 Ram 3500HD 6.7L CTD 4x4 CCSB
2017 CC 34RL2 Hathaway Edition
Andersen Ultimate 5th Wheel Hitch
Nights Camped: 2017=5 | Booked=38
florabama is offline   Reply With Quote
Old 10-09-2016, 09:07 PM   #2
Retired JSO's Avatar
We had heat-pumps in our motorhome and they really worked great here in Florida. While some units will not work below 35, ours would work just below below freezing. If and when we need a replacement, it will be a heat-pump.
Retired JSO is offline   Reply With Quote
Old 10-09-2016, 09:47 PM   #3
SnP
We have the heat pump option on our current CC and will be ordering it again on the soon to be ordered Champagne. It is nice to put the thermostat in heat pump mode and set temperature and that heats whole RV on campground electricity. Saves a lot of propane heating and the costs associated with that.
Steve and Paula
Tiki and Keyla (Our Papillon Kids) RIP Chance
2015 Ford F-350 DRW, 2015 Cedar Creek 34RLSA-7
Camped - 2014-47, 2015-104, 2016-100, 2017-0
SnP is offline   Reply With Quote
Old 10-09-2016, 09:54 PM   #4
Bluepill's Avatar
I have heat pumps in my camper and my Motor Home. Both came as standard. When camping in weather down to about 40 degrees they work well. Below that, I use propane.
One thing I do not like about heat pumps below about 45 degrees outside temp. is that the air they supply is not very warm at the outlets. Something around 120 degrees, vs. 160 or more from the propane. It just feels almost cool in comparison.
2008 Itasca Meridian 37H
Old 10-09-2016, 11:26 PM   #5
Iggy's Avatar
Are you talking about needing it in Florida?
If you are looking for a Cedar Creek most of them come with electric fire places and are very efficient. I have used mine instead of the propane heaters while up in cold climates like Yellowstone NP when the nights got down to mid to upper 30's.
2012 Georgetown XL - 378TS
Old 10-10-2016, 03:31 AM   #6
Witch Doctor's Avatar
It is worth the money up front, I would get it as an option, It would cost you more then that to add a heat strip later to an A/C unit plus you would need to add a stat wire to make it work, good luck with that one, I have checked on this already, I hope I never have to change my A/C but if I do it will be replaced with a HP...
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 10-10-2016, 12:14 PM   #7
Stevemc's Avatar
We have the heat pump option on our also and it is great not to have to use the the furnace on those 40 - 50 degree nights.
Steve & Jean
Furbaby - T.J.
Towmotor - 2013 Chevy LT DRW Duramax/Allison
5er - 2013 Cedar Creek 36CKTS Classic Champagne Touring Edition
Stevemc is online now   Reply With Quote
Old 10-10-2016, 01:46 PM   #8
Boso's Avatar
Heat pump
Have had several without and several with I would say always go with the heatpump if it is an option
Boso is offline   Reply With Quote
Old 10-10-2016, 04:03 PM   #9
Not sure about Cedar Creek but in my MH heat pumps came with larger output Air Cond. the heat pumps work great. Self use the furnace unless below 40 degrees. Well work the $$$
edcronin01 is offline   Reply With Quote
Old 10-10-2016, 05:44 PM   #10
Ditto, I had a heat pump installed after my first a/c crapped out, and I loved it! You will too!
floridela is offline   Reply With Quote
pump, upgrade
