Old 04-03-2013, 07:24 PM   #1
Heating - A/C issue
Hi All,
Just returned from my break in trip to Elk Neck State Park with the new 38FL. Everything mostly worked well, but we had an interesting problem. When the furnace is turned on in zone 1, the A/C unit comes on as well. Both are running at the same time. Naturally, when I only kick on the A/C, the heater doesn't fire up with that. Seems like it might be miswired at the digital thermostat? Has anyone else experienced this?
If it is an easy fix, I would rather not drive it all the way to the dealer for the warranty work.
Thanks in advance for any help,
Don
Don and Michele
3 Adult Children - 5 Grandchildren
Present campsite - future homesitehttps://i246.photobucket.com/albums/gg119/dmdrj5/lake/dividingcreekviewfromhouselocation.jpg?t=120311985  4
dmdrj5 is offline   Reply With Quote
Old 04-03-2013, 07:37 PM   #2
Dave_Monica's Avatar
Check on the thermostat that the fan is set in auto not the on position. If it's in the on position it will do what you describe.
Dave
Old 04-03-2013, 08:20 PM   #3
Dometic single zone thermostat? Look at page 8 & 9 in the T-stat manual.
Old 04-03-2013, 08:24 PM   #4
Always Learning
A day late and a dollar short... what they said ^^^^.
Old 04-04-2013, 06:55 AM   #5
There is no "on" setting for the fan on the digital thermostat; just low, medium and high settings. There is an "auto" setting under the "mode" settings, along with furnace, cool, fan, etc.
My thermostat manual only has 4 pages and just shows how to push the buttons for what you want to achieve.
Don and Michele
Old 04-04-2013, 07:32 AM   #6
jtstromsburg's Avatar
Yup. On fan, switch to auto as they said. Then cycle back to heat and set your desired temp. Low/high wool make the AC fan run continuously.
Edit.. Post a picture of your stat if possible. Maybe different then we are thinking
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 04-04-2013, 07:38 AM   #7
Triguy's Avatar
Good idea to post a pic of that T-stat or a make and model number just so are all on the same page.
Note we have a few T-stat manuals in the forum library (found on the menu bar above). Or, go here...
Forest River Forums - Downloads - Heating and Cooling
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 04-04-2013, 01:13 PM   #8
Dometic comfort control center 2 thermostat: model# 3314080.xxx
Don and Michele
Old 04-04-2013, 01:18 PM   #9
I have that stat. The fan button is to the left of "Mode".
Old 04-06-2013, 05:39 PM   #10
I finally found a more extensive owner's manual.
Thanks for all of the help. I still don't understand how they think it is a good idea for the AC to come on while the furnace is running just because the fan is not on auto.
Thanks again,
Don
Don and Michele
Old 04-06-2013, 08:13 PM   #11
Thanks again,
Don
The fan settings on the thermostat only control the AC fan not the furnace fan. I use the fan in the 'on' position will using the AC to help circulation in the camper.
Dave
