Old 09-16-2014, 02:59 PM   #1
ret2006's Avatar
Hehr insulated (thermal pane) window fogging.
Has anyone with the Hehr thermal pane windows had any seal problems and fogging? My CC is 15 months old and I just noticed one of the living room tilt out windows is starting to fog between the two panes.
I purchased the second year warranty so hopefully replacement will be covered. Can just the one window be replaced or will the entire window with 4 panes and frame have to be replaced?
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
Old 09-17-2014, 05:17 PM   #2
Campingnut's Avatar
The crank out windows can be replaced without replacing the whole window. All my windows (crank out) have separated, just hot glue and foam tape holding them together. Mine are also only 15 months old but I did not purchase the extended warranty and they are not covered. I think the reason mine have the problem is that the outside pain is contacting the frame before the inside is contacting the frame and when you close them it wants to pull the two apart. I am in the process of glueing them back together myself (I am hoping to do it this weekend). The windows are pricey at about $300 a window.
Tim and Bev
2013 Cedar Creek 34RLSA, Magnum 2800w inverter, 560w of solar.
2015 F-350
Campingnut is offline   Reply With Quote
