Originally Posted by BoatDude
We do our walk through this weekend. We are very nervous. If you have any suggestions for our walk through please advise. Thanks Vic & Ruth.
Congrats on your new CC.
Here are some tried tips.
Bring a video camera/smartphone.
Ask questions.
Make sure you understand how systems work before you pull out.
Make sure the pinbox, hitch are aligned for
a level ride with 6" of clearance above the bed rail. Trail Air inflated.
Have the unit plugged in to 50amp service
before you start.
Make sure your batteries (4x6volt with res reefer) are properly installed.
Turn everything on as you go.
Make sure you have water in the tank and
test the pump.
Make very sure the slides work and are aligned... Bring a level.
Make sure the level up is calibrated.
Cook top must be level.
Dining table fairly level.
Island level. Bath floor level
Look at the gap on the slides open and closed. Make sure they seal.
Check the pipe & drain fittings. Hand tight. Run the water. Flush the toilet.
Lights on. Lights off.
Fans on. Fans off.
A/C - Heat
How does that thermostat work...
Tire pressure. Lugs torqued.
Vacuum attachments.
Spare tire crank wrench.
Hoosier counter top slide?
Command center
Utility center.
LP full.
TV(s) & Antenna work. (Antenna down;-)
Appliances work
Check bed strut mounts.
Closet door locks.
About the only thing I didn't do at the PDI was blow up the bed.
Suggestions for Basics:
Get a good water pressure regulator and set it to around 50 lbs.
Chocks are needed.
Sewer hose. Suggest 2x10'
Potable water hose. Suggest 2x25'
Sewer connection elbow and donut.
Surge suppressor with built in line testing.
50amp to 30amp adapter.
Hope this gets you started on the right path.
Happy Trails...
