Old 09-10-2016, 04:51 PM   #1
Help fridge leaning
Just drove 6 hrs and when we went to set up. The refrigerator is leaning forward. I have a 31RK. I can tilt it forward, but I can't move the front. It seems it is bolted down some how. I need to move it forward so I can see what's making it lean. Does anyone know what is holding the front of the refrigerator down?
mbienve is offline   Reply With Quote
Old 09-10-2016, 05:03 PM   #2
ryand's Avatar
Can you post a photo? What model fridge?
2011 Coachmen Catalina 28DDS
2015 Ram Bighorn 2500 6.4L
http://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
Old 09-10-2016, 05:10 PM   #3
I have a Whirlpool refrigerator. And the camper is a 2016 model. I'll try to post pictures later.
Old 09-10-2016, 05:32 PM   #4
Name:	ImageUploadedByForest River Forums1473546683.518003.jpg
ID:	119891Click image for larger version
Name:	ImageUploadedByForest River Forums1473546696.721139.jpg
Here are the pictures.
Old 09-10-2016, 05:35 PM   #5
ryand's Avatar
Do you see any brackets on the floor when you open the door?? If so you many need to remove the brackets and pull it out to see what's going on. Sorry I couldn't be more help. Can you move it at all?
Old 09-10-2016, 08:18 PM   #6
I can tilt it forward, so the rear of the unit is loose. But the front is not budging. There is a board under the front ahead of the wheels. But the head of the screws are being block by the bottom of the unit. Click image for larger version
Name:	ImageUploadedByForest River Forums1473556673.149339.jpg
Old 09-10-2016, 08:39 PM   #7
ryand's Avatar
Can you push the fridge back to access the screws?? If not you may need to empty and lift the fridge over the floor stop.
Old 09-13-2016, 07:42 PM   #8
mbbutler's Avatar
X2 on pushing bottom back! Been there
2016 Cedar Creek Silverback 33IK
2008 Ford F-250 Crew Cab 4x4
mbbutler is offline   Reply With Quote
Old 09-13-2016, 10:14 PM   #9
Update:
There is a board at the top rear of the refrigerator to hold it down. What happened was, while traveling the refrigerator tilted forward forcing the board to give just enough that it released it. When the refrigerator fell back, the board was now between the refrigerator and the wall. Preventing it from straighten out.
So all I had to do was unscrew the board and the refrigerator fell back into place. I replaced the board on top of the refrigerator and all is back to normal now. Thanks to all who tried to help.
Name:	ImageUploadedByForest River Forums1473822853.939302.jpg
Old 09-18-2016, 09:27 AM   #10
Had the same problem with the same setup as you. Took it to the dealer and they added another brace to secure the back of the fridge.
Henry16415 is offline   Reply With Quote
fridge
