Old 04-07-2019, 08:49 PM   #1
Help me get ice maker working - 2020 Cedar Creek Hathaway
HI. We just purchased a 2020 Cedar Creek Hathaway. When we took delivery of it and once we got it home from three states away and realized that most of the odds and ends were not set up or turned on etc. We have figured out most of it, now trying to get the ice maker to work. Does it have a water line going to it? Can anyone help me to even figure out where the turn on is?
cherlyn is offline   Reply With Quote
Old 04-07-2019, 09:02 PM   #2
keith52's Avatar
I'm going to assume that you have a residential refrigerator. There is a water line going to the rear it. On my 2017 the water shut off is located under the kitchen slide near the axles and up against the frame. Look for something like this....
Name:	Ice Maker Line Valve.jpg
2014 Chevy CC Duramax 4X4 Long Bed
2017 Cedar Creek 36CKTS
MORryde independent suspension with disc brakes
keith52 is offline   Reply With Quote
Old 04-08-2019, 11:03 AM   #3
edt
It is probably a put to open instead of a pull
North Ga
2015 40' cls
Never to be moved
edt is offline   Reply With Quote
Old 04-08-2019, 12:15 PM   #4
Thank you for your response! We opened that and we are still not having any luck. We turned ice machine on on outside of residential refrigerator. Is there anything behind fridge that needs to be turned on?
Old 04-08-2019, 12:24 PM   #5
You do have city water hooked up or water pump if pulling from fresh tank???
gbaldwin is offline   Reply With Quote
Old 04-09-2019, 01:27 PM   #6
Retired Member
rmwmiata's Avatar
We have an on/off switch inside freezer above ice bin.
rmwmiata is offline   Reply With Quote
Old 04-09-2019, 01:51 PM   #7
B and B's Avatar
Dealer PDI Ice Maker Instructions neglected
Hello, is there a valve under the kitchen sink? Many other brands do this.
Old 04-09-2019, 02:39 PM   #8
Dumb question, but did you pull the bail on the icemaker down?
The "bail" is the bent rod which shuts the icemaker off when the bucket gets full or when you pull it up to shut the icemaker off.
Larry
Larry-NC is offline   Reply With Quote
Old 04-09-2019, 02:40 PM   #9
I have a 2018 CC Silverback 37FLK with the same setup and could not get water to the fridge. My problem ended up being a kinked water line behind fridge. Once I pulled it away from the wall it was easy to see the problem.
clarktod is offline   Reply With Quote
Old 04-09-2019, 04:29 PM   #10
Maybe
Our new Columbus has a small outside the unit door you open up behind the fridge area and inside is a small on/off valve to turn on or off the icemaker.
Lake5er
2019 Columbus Compass
M329DVC
Lake5er is offline   Reply With Quote
Old 04-09-2019, 08:16 PM   #11
Thank you this was evidently part of the problem! No where have we found where all of these valves are. Thank you very much !
Old 04-09-2019, 08:17 PM   #12
Thank you this was the problem pushing is what we needed to do! Thanks for ypur response!
Old 04-09-2019, 08:19 PM   #13
Thank you for tour response !
Old 04-10-2019, 08:50 AM   #14
Global Nomad
Scheinin's Avatar
In your cedar creek, how did you pull residential fridge from wall? Did you have to release something?
Steven J. Scheinin
2015 RAM 3500 4X4
6.7L CTD Dually pulling a
2016 Cedar Creek 36CKTS
Scheinin is offline   Reply With Quote
Old 04-19-2019, 10:42 AM   #15
There were two screws at the top through a L bracket that where attached to the wall and two on the bottom that held it to the floor behind the grill.
Sorry for the late response. I don't check these forums often.
Todd
Old 04-19-2019, 11:31 AM   #16
Global Nomad
Scheinin's Avatar
Todd
Thank you. Mine must be different, as I have looked and looked and see no brackets, top or bottom. It appears that if I retract the leveling feet by the front rollers, it should just pull out. I will do that as a last resort.
Steven J. Scheinin
2015 RAM 3500 4X4
Old 04-19-2019, 12:39 PM   #17
Our residential refrigerator was held in place by a L bracket on top of the refrigerator. The refrigerator was sitting on what looked like a small pallet. The pallet collapsed and the refrigerator fell off the mount. So then the refrigerator was half in and half out. We had to push the refrigerator up so we could get the slide. We ended up taking the Cedar Creek to custom rv shop in Pigeon Forge TN. They charged two hundred bucks, the refrigerator looks great now, no more problems. I would like to find another door for the refrigerator
spock123 is offline   Reply With Quote
Old 04-21-2019, 06:33 AM   #18
mbbutler's Avatar
First batch of ice can take up to 24 hours.
mbbutler is offline   Reply With Quote
Old 04-25-2019, 12:09 PM   #19
The freezer must be good and cold before it will make ice. If you want to, you can force the ice maker to go through a cycle.
IMPORTANT!!! The ice maker works on 120 volts AC. Don't touch the bare ends of the wire when you perform this procedure.
Remove the cover from the end of the ice maker. You should see a large gear and directly under this there are two test ports marked T and H. You will need a short piece of insulated wire with the ends stripped to a 1/2" bare. Bend the wire and push both ends into the ports. The gear will start to move and you should hear a small click in about 5 seconds. Remove the wire. The ice maker will cycle and the water solenoid will open. You should hear water flowing, if there is pressure.
2012 CC 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 04-25-2019, 05:34 PM   #20
If you have a water fill system in your refrigerator, run water thru it until you get all the air out. Then your ice maker will probably work
ccjdcamaro is offline   Reply With Quote
cedar creek
