Old 06-10-2014, 03:16 PM   #51
BamaBob's Avatar
Originally Posted by dcheatwood View Post
And now, if the rain holds off, I'm back on my issue witht eh frig not cooling. AFter about 18 hours on 120V, it was at 40 degrees this morning, but back up to 46 now and has not been opened. Gonna turn all the fans over.
Dave,
I believe OC did some sort of mod that improved cooling on his unit.
From my Foxhole, it sounds like your unit is cooling (no ammonia smell right?) So if your unit is cooling I wonder how the seals are doing on your fridge?
Is your freezer functioning correctly?
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 06-10-2014, 03:33 PM   #52
dcheatwood's Avatar
Originally Posted by HSVBamaBob View Post
Dave,
Yeah, freezer is fine but like many others have reported, not cold in frig. I just put 3 fans (original with thermistor and two switched) in the rear pointing up to suck cooler air in the bottom and warmer air out the top. I've tested the door with a dollar and it was fine. My 3rd rv with dometic and never had an issue before. But this is first one with frig in slide out. Guess circulation is not as adequate as roof vent. No ammonia smell. Holding now at 44 degrees with ori fan cycling. I'm gonna watch it a while and then turn on 2 other fans to see if any change. I have a temp transmitter in the frig so I can read temp from the house and no need to open door. hasn't opened in about 15 hours now.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 06-10-2014, 03:40 PM   #53
Ford Idaho's Avatar
Thought the fan/s were supposed to be in the fridge blowing on the cooling fins.
Interesting, I shall watch.
Old 06-10-2014, 03:45 PM   #54
BamaBob's Avatar
Yeah, freezer is fine but like many others have reported, not cold in frig. I just put 3 fans (original with thermistor and two switched) in the rear pointing up to suck cooler air in the bottom and wormer air out the top. I've tested the door with a dollar and it was fine. My 3rd rv with dometic and never had an issue before. But this is first one with frig in slide out. Guess circulation is not as adequate as roof vent. No ammonia smell. Holding now at 44 degrees with ori fan cycling. I'm gonna watch it a while and then turn on 2 other fans to see if any change. I have a temp transmitter in the frig so I can read temp from the house and no need to open door. hasn't opened in about 15 hours now.
Dave,
I was doing some research for you and found this:
Purchase | Buy RV Fridge Control | Norcold Documentation | Dometic Documentation
Don't know if it is worth anything or not...would love to hear opinions!
Hmmm My refer is on the slide as well. Over Memorial Day weekend, I noticed that the refer was making a whining (or steady tone) sound. No issues with cooling, just that odd sound which I attributed to cooling during the heat of the day (got up to 93 deg with @ 70% humidity )
I have thought about installing a fan(s) in our refer as well - this sounds like a mod I need to do.Soon.
This temp issue has got to be driving you crazy!!
Old 06-10-2014, 03:49 PM   #55
Fans inside are to keep the temp even, not lower it, the fans outside blowing across the entire back is what will help LOWER the frig temp. Fans down as close to the burner as possible as it cools the entire coolant plumbing system.
Old 06-10-2014, 04:00 PM   #56
NELA
Weezer's Avatar
Wow! Thought about BigJohn and his family several times today...*tough* work day BTW, and now to come home to such a wonderful story!
dcheatwood......A boisterous and LOUD round of applause for ya!
I know this awesome group of people came to our aid when we had the smoke alarm go off in the early morning hours and woke up to an RV full of smoke. Saved our trip, they did!
SO glad that John can now exhale and relax for the rest of his offshore rotation, knowing all is well at the home front.
BTW John, you've created quite a stir here at home....your home front set-up is EXACTLY what DH has been planning for us. He spent HOURS online last night researching metal buildings big enough for a small apartment, his shop, and our 5er. ...... He's officially on a mission now!
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 06-10-2014, 04:16 PM   #57
dcheatwood's Avatar
FI. I think some are in the bottom. Mine came with 1 fan mounted just beneath the upper fins blowing down. I'm sure it should have been blowing up as heat rises. So I put one one either side that I can turn on and off on hotter days.
Sent from my XT907 using Forest River Forums mobile app
Old 06-10-2014, 06:27 PM   #58
Plain Old Member
This may be totally worthless info, but this is what I did to the fridge in our Forester. It was in the slide and the cooling fan seemed to work ok. It was only a single fan, but blowing upwards across the coils. After I cut the original thermister off inside the fridge and did this cheap $26 mod, I never had any other issues. It was an experimental mod, but it worked then. In our case, I couldn't get the temp set the way I wanted it. It was always too warm.
Dometic Thermistor Repair Kit
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 06-10-2014, 07:35 PM   #59
dcheatwood's Avatar
I've been thinking about one of those. Had never heard a report about effectiveness. Thanks for telling me.
Old 06-10-2014, 08:26 PM   #60
BillyBass's Avatar
Originally Posted by Herk7769 View Post
You could also make a fused jumper to manually open and close the awning (at the switch location) in a pinch.
What was the problem with the awning in case it happens to me thanks
2012 21' FR Micro Lite FBRS
2005 GMC Sierra 1500
2012 24 nites 2016 16 nites
2013 25 nites 2017 19 nites
2014 14 nites
2015 16 nites
BillyBass is offline   Reply With Quote
awning, power
