Old 07-11-2015, 02:21 PM   #1
Av8orLou's Avatar
Help slide Problem
I have a 2013 CC 34 Rlsa and my slides won't work. All the fuses and breakers seam to be working. I have the level up system and it works. Yes the pump is working, but when I press the button to work the slides, the pump activates and sounds like it is working normal but nothing works. All slides are on the one switch. I tried isolating the 3 slides and operating one by one but none of them worked. The last time I was in it about a month ago I had to isolate the main slide (turn it off and allow the other two slides out) because it was sitting next to another RV at the storage facility, other than that it was fine until now. Please help.
2015 GMC Denali HD Z71 4X4 - D/A
2004.5 Chevy D/A
2013 Cedar Creek 34rlsa
2003 Four Winns Funship 214 Deckboat - Hawaiian Breeze
Av8orLou is offline   Reply With Quote
Old 07-11-2015, 02:24 PM   #2
Av8orLou's Avatar
Oh and the battery is fully charged
2004.5 Chevy D/A
Old 07-11-2015, 02:32 PM   #3
Have you checked the hydraulic fluid level?
2014 CC 34RLSA
2013 RAM 3500 Laramie CC SB 4x4 CTD
sidney is offline   Reply With Quote
Old 07-11-2015, 02:35 PM   #4
Av8orLou's Avatar
Yes fluid level is good
2004.5 Chevy D/A
Old 07-11-2015, 02:46 PM   #5
Mine did the same thing... resetting the breakers fixed it... but since you already checked the breakers I'm stumped.
2014 CC 34RLSA
Old 07-11-2015, 08:06 PM   #6
arpipeliner's Avatar
Possibly have all the isolating valves to off position?
arpipeliner is offline   Reply With Quote
Old 07-11-2015, 08:13 PM   #7
Av8orLou's Avatar
No they are all open and I cycled them a few times
2004.5 Chevy D/A
Old 07-11-2015, 08:43 PM   #8
Does your model have the slideout lock out switch?
If not. And the resets are good you have stumped me. Doesn't make sense the pump kicks in and no action.
Name:	ImageUploadedByForest River Forums1436665410.530726.jpg
The middle switch.
Old 07-11-2015, 09:19 PM   #9
Av8orLou's Avatar
Yes it does have the switch and it is in the on position
2004.5 Chevy D/A
Old 07-11-2015, 09:53 PM   #10
Former Full Timer
Duckogram's Avatar
Sometimes the connector on the valve bank can get loose or corrode. My shot in the dark recommendation is to pull each connector and check them. I strongly suggest doing one at a time if you do this. Since all 3 slides are effected, I'm thinking its the main bank solenoid and not the 3 individual slide valves (if you have more than 1). Hope this helps.
Edit: There is a manual bypass valve if the solenoid is toast.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
slide
