Help, We're taking on water...
I found something others may have to check on. I found I had a leak in the bedroom after a bad storm with the slide in. I checked everywhere to try and find where it came in at. The slide seals very well and tight all the way around. In the mean time we had another storm and once again it leaked... The only place and where I believe it came in at is the metal trim around the slide. They have silicone that should seal the trim. The silicone is not in the crack and has pulled away. I think it was running down in behind the trim plate and then under the slide between the plastic shield and slide floor. I have resealed it and hope that is where it was. Just waiting on the next rain storm.... In the mean time check the caulking around the trim on your slides......
From Central Texas
2014 Cedar Creek Silverback 29IK
2010 Dodge Laramie 3500 Dually
My Steelpony....2007 HD Ultra Classic...done up in a memorial to the 343 firefighters who died 9/11
Never Ever Forget....yes I was a Volunteer FF for 20 years........
