Old 10-14-2016, 02:19 PM   #11
Yes please tell...
Duallynewt is offline   Reply With Quote
Old 10-14-2016, 03:21 PM   #12
Tankless water heater can either be drained by opening a valve on the back of it which is hidden behind a plate you can't reach to remove or you can just leave everything alone including the bypass valve and run anti-freeze through the unit. It only holds 2 qts. That's what I did.
The ice maker can be a problem..I don't know if I got mine done correctly or not. This a stupid system and if I freeze the solenoid I have no plans to fix it. Don't care if it works or not. Here goes according to the Forest River winterizing guide...Open the low point by the back wheel and drain the line to the ice maker. Cap the line and pull anti-freeze through the system in the normal way...Here comes the tough part: Leave the ice maker on and let it cycle through until the ice cubes come out pink. Mine makes ice at the rate of one small batch per hour. It would take several hours of sitting there watching for pink ice to know if this is done right or not..The alternat method is to drain the system and don't use anti-freeze and let the ice maker cycle until nothing more comes out...I don't know about you but I have no plans to sit around all day waiting for pink ice cubes...Ther must be a better way but I don't know what it is. I'm hoping someone at Whirlpool can tell me how to force the ice maker to cycle more often to flush it out...Haven't found the right person there to ask..YET.
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
Old 10-14-2016, 03:29 PM   #13
Duplicate post
Old 10-14-2016, 07:00 PM   #14
Fixed one problem, going to order unit with gas/electric hot water heater. Guy in campground has Champagne model and hates tankless heater. We don't have sewer hookup and get pumped out weekly, so waiting for water to get hot is not an option. The Champagne guy had his unit winterized today by the dealer. They pulled the refer out, unhooked water line, and jumped the solenoid to cycle it. Didn't see it but will watch next year if we get one. On another note, his wife hates induction cook top. It replaces the range and thus must use microwave convection oven to bake with. They changing the color on the Hathaway editions to a burgundy accent. Not sure whether that will make it look dated in a few years.
todalake is offline   Reply With Quote
Old 10-14-2016, 11:31 PM   #15
racer4's Avatar
Question on the Tankless On Demand Water Heater:
How much water drained out when you opened the drain valve?
I got about 1 or 2 ounces. That does not seem like enough.
I had all the faucets open, and had already opened the front and rear low point drains. Then opened the drain valve for On Demand water heater. About 1 or 2 ounces drained out of the hose below the water heater.
Does that seem right?
Chris and Pat
2016 Ram 3500 Cummins Aisin Dually 4.10 axle ratio Auto Flex Air Ride Rear Suspension
2017 Cedar Creek 36CKTS
racer4 is offline   Reply With Quote
Old 10-15-2016, 06:46 AM   #16
wls
if nobody answers, late tomorrow I may winterize mine will post here.
2008 Dodge 3500 Dually, Cummins. Amsoil Bypass Oil Filter, 36 Gal aux fuel tank. Mag Hytec Trans pan. Mag Hytec Diff Pan. 6 speed autostick. 3:73, Timbrens, Smarty JR. Equipped.
2016 Cedar Creek 38FB2
2016 Camping Days=38
wls is offline   Reply With Quote
Old 10-15-2016, 10:09 AM   #17
The people at Suburban told me the on-demand water heater only holds about 2 qts. No way I can get to the back of mine to unscrew the little panel and turn the little valve he was talking about. He also said it would be okay if I just left the bypass alone and ran antifreeze through on my way to winterizing the hot water faucets. That's what I did..
winter, winterize
