Old 09-20-2015, 08:09 PM   #1
jaygeo1's Avatar
Honda 2000 generators in parallel questions....
A question for Forum members using a pair of the Honda 2000's....can the auto idle "ECO" switches be turned ON while powering the coach and running the AC? Or, do you run one generator with the switch ON and the other OFF?
I have one Honda 2000 now and will be getting a second one (companion) next season. Our 5er has one AC.
Would appreciate any comments you may have about your 2000's.
jaygeo1 is offline   Reply With Quote
Old 09-20-2015, 08:44 PM   #2
strat56's Avatar
I only have one but I believe the Honda literature says they both need to be set the same, they should both have ECO on or off.
Jack and Jan
Nights camped 2014 - 8 | Nights camped 2015 - 23 | Nights camped 2016 - 24
2015 Ford Super Duty F350 > Blue Ox Swaypro WD Hitch > 2015 Rockwood Windjammer 3008W
strat56 is offline   Reply With Quote
Old 09-20-2015, 08:59 PM   #3
If running both in eco mode, you might get just enough delay in amperage so that the A/C surge while starting up will trip the Honda breakers. Better to keep them both with eco off when running A/C.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 09-20-2015, 09:18 PM   #4
HONDAMAN174's Avatar
I think they run just fine in Eco mode. Being that the fan powers up first it will take the pair out of idle.
It's been a long time since I have used my pair for ac so not hold me to it.
Just glad to get away
Old 09-21-2015, 12:25 AM   #5
340_Formula_S's Avatar
I run both in Eco mode and run my A/C.
Elko, Va.
2012 Ram 3500 DRW Cummins High Output
Cedar Creek 36B2
340_Formula_S is offline   Reply With Quote
Old 09-21-2015, 08:48 AM   #6
oldgold's Avatar
I kept both of mine in Eco mode for everything. Never had any issues with the AC. I would power the generators and let them warm up a little bit before you put a load on them though.
Keeping them in Eco mode will allow them to idle back more when your AC is cycling off as well.
2015 XLR Nitro 30FQSL
2015 F250 King Ranch
oldgold is offline   Reply With Quote
Old 09-22-2015, 12:23 AM   #7
moondog2000's Avatar
I have run mine in eco mode all summer camping. Seems to work ok, very good on gas.
05 Silverado Z71 4X4
2013 Forest River X-LITE
Days camped in 2018, 9
moondog2000 is offline   Reply With Quote
Old 09-22-2015, 04:22 AM   #8
Head Dog
I have two of the 2000 watts connected in parallel. I called the honda headquarters in Georgia and they stated that the generators were not to be set in Eco stage while running your unit, especially with the air conditioning. They possibly could be set in Eco without the air, but they do not recommend that. Too much hesitation if in Eco and the air comes on.
jhward90 is offline   Reply With Quote
Old 09-22-2015, 11:05 PM   #9
I noticed when in the eco mode and the a/c compressor cycled back on there was a power dip almost like the unit came to a stop and then came up to speed. I checked amperage with my amprobe and did not see a large spike so I contingued to run in eco mode because its just above an idle verses 2 gens wide open.
generator
