Old 05-09-2015, 09:34 AM   #1
Hot water seems too hot
Hot water seems awfully hot, hot water smokes coming out of faucet
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 05-09-2015, 09:49 AM   #2
Evereddie's Avatar
Not good. Sounds like a malfunctioning thermostat. Are you on electric or propane. Whichever you are on you could get a temporary fix by switching to the other heating method if you can. As long as you are not boondocking.
There are 10 types of people in the world.
Those that know binary, and those that don't.
2013:31 / 2014:51 / 2015:58 / 2016:37 / 2017:46
2018:16
Total 239
Evereddie is offline   Reply With Quote
Old 05-09-2015, 09:54 AM   #3
Flybob's Avatar
If the water gets too hot, it will trip the over temp protection.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-09-2015, 11:34 AM   #4
UmptySquat's Avatar
Originally Posted by spock123 View Post
Hot water seems awfully hot, hot water smokes coming out of faucet.
Ours does the same. Brand new Apex. I looked forever for an adjustment and it just seems to be a fixed temp. I don't think ours is a malfunction, just a higher than we're used to setting.
2013 Toyota Tundra 5.7L
2015 Apex 288BHS
UmptySquat is offline   Reply With Quote
Old 05-09-2015, 12:17 PM   #5
Evereddie's Avatar
I was told that there are adjustable thermostats under rubber like covers on the heater . But different makes of heaters are different I'm sure.
2018:16
Total 239
Old 05-09-2015, 12:24 PM   #6
Don't think it has an adjustable thermostat. Most, if not all rv water heaters come with "fixed temperature" hi limits from the factory. One is 12V for propane and the other is for 110V.
Old 05-09-2015, 12:40 PM   #7
Evereddie's Avatar
Ok , good information. I know I read on this forum where someone somehow raised the hot water temperature giving them more shower time. I have done that in my house when I had the whole crew in the house. Maybe they replaced the thermostat with a higher temp unit.
2018:16
Total 239
Old 05-09-2015, 12:49 PM   #8
That's what I did, replaced the factory 130 hi limits and replace both with 142 ones. Like it much better and it makes the hot water last longer or at least it sure seems too.
Old 05-09-2015, 01:00 PM   #9
Evereddie's Avatar
Yup, it really does make the run times of total showers events longer since the mix of water takes less hot by volume.
2018:16
Total 239
Old 05-09-2015, 01:16 PM   #10
Oakman's Avatar
The hotter the water the more cold water you can mix into it for showers making for longer showers.
You can check the actual temp of the water easily enough by placing a meat thermometer under the hot water. Meat thermometers are pretty cheap at WalMart.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
hot water, water
