Old 08-14-2016, 06:19 PM   #1
jmh
Hot water tank
A friend of mine just bought a 2012 cc 36 ckts. This weekend was his 1 st trip with it. After being hooked up for about 2 hrs I noticed water dripping from where the hot water tank is located. We turned the supply line off to the tank and it stopped. More than likely tank leaking. Is there anything else I should check. Turned water back on started dripping again. How difficult is it to change tank. It's a 12 gallon suburban.
jmh is offline   Reply With Quote
Old 08-14-2016, 06:23 PM   #2
Normal weeping from overflow valve. Ignore it.
johnbryanpeters is offline   Reply With Quote
Old 08-14-2016, 06:29 PM   #3
jmh
Thanks for the reply. This is more than just a little drip. It's just guessing about a gallon every 2hours.
Old 08-14-2016, 06:37 PM   #4
There's a handle on the overflow valve. Lift it briefly to blow out any debris.
Old 08-14-2016, 06:39 PM   #5
jmh
Did that several times
Old 08-14-2016, 06:41 PM   #6
jmh
Are talking about the pressure relief valve
Old 08-14-2016, 06:53 PM   #7
TURBS's Avatar
Water leaking from the pressure relief valve is "not normal"
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "25"
Old 08-14-2016, 06:57 PM   #8
jmh
It's not leaking from relief valve. It's coming from front of tank. Behind the panel on side of camper. When looking at back of tank, you can see water seeping from under tank. Checked all fittings and none are leaking.
Old 08-14-2016, 07:10 PM   #9
I have a 2013/14 32RCTS. Last summer the hot water check valve on the rear of the heater cracked. It was plastic. With some assistance from my camping neighbors we managed to pull the heater and replace with a brass check valve. Purchased an extra just for good measure. Can you see the cold water in/hot water out fittings on the back of the heater?
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 08-14-2016, 07:12 PM   #10
Since it's a used Cedar Creek it may not have been winterized right. I would not think the hot water tank would leak this soon, it's only four years old
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
hot water, tank, water, water tank
