Old 04-20-2014, 10:16 AM   #1
Sewhappy's Avatar
How do you get the clamps to fit in the sewer hose storage pipe?
My DH went out side with different sewer hoses and the hoses fit in the storage pipe but the end caps are too big. How do you make it work? What are we missing? We have a CC 36 ckts.
Sewhappy is offline   Reply With Quote
Old 04-20-2014, 10:32 AM   #2
On mine,I have to turn the ends side ways across to get them in.
DaveandSue is offline   Reply With Quote
Old 04-20-2014, 10:38 AM   #3
Sewhappy's Avatar
I will try that. What brand of sewer hose did you get?
Old 04-20-2014, 10:52 AM   #4
arpipeliner's Avatar
Are u talking about storing in the bumper or hooking up to drain?
arpipeliner is offline   Reply With Quote
Old 04-20-2014, 11:00 AM   #5
Yes it has to basically turn on the diagonal so the hose fittings end up at the opposite corners or you will never get it in. It JUST fits, but not by much.
Mark B.
2021 GMC 1500
Anderson WDH
markb5900 is offline   Reply With Quote
Old 04-20-2014, 03:17 PM   #6
Sewhappy's Avatar
I am talking about the sewer hose compartment that is built in the side of the CC 36 ckts. We got a Campco sewer hose. The hose fits great but there is no way the coupling is going to fit any way you turn it. The Rhino was the same.
Old 04-20-2014, 03:25 PM   #7
Mine is the same way. I just put the two ends together making a sealed loop and put in the front storage normally. I am careful not to let it rub or get punctured. The only other option is have seen is putting a PVC pipe with ends that is big enough. I have seen zip ties and hose clamps. I just don't want it on the back of my camper. If they make a bigger bumper I don't know of it.
Old 04-20-2014, 08:30 PM   #8
The better hoses with good ends will not fit into the CC "Sewer Hose" carrier...We have added a "Fence-post" carrier. But you can also now purchase larger carriers now... The existing hose carrier on our rig contains the clothes line...
Sanitubes / Sewer Hose Carriers / SUPER-TUBE - DW Inc.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 04-20-2014, 08:39 PM   #9
Sewhappy's Avatar
The fence post was a good idea. Thanks for the link also.
Old 04-20-2014, 08:55 PM   #10
Brother Les's Avatar
Your spare tire seems to be riding really close to the ground.
Brother Les
Old 04-20-2014, 08:58 PM   #11
It is an "optical illusion".... Actually the drive area where the rig sits slopes up to the back of the rig sharply after where the tires sit so it is very close due to the rig leveling out. Although it does hang lower than our previous rig it is no all that close to the ground when on level ground.
Walter & Donna
Old 04-21-2014, 06:33 AM   #12
Certified Curmudgeon
There are some mods to the anemic storage tube posted within the last year or so in addition to the fence post and screw cap PVC tube options.
The one with the larger door and slide out trough caught my attention.
Mike Dropped
Old 04-21-2014, 10:51 AM   #13
cbvp's Avatar
Sewer Hose Storage 36 CKTS
Here's the problem.
Take FR round tube off of Door assembly then attach it to a 5"X5" fence post cover. Seal other end with a post cap silicone on. You can make the post cover as long as you want. Check to make sure nothing is going to interfere with the post cover sliding it 5' or 6' into side of unit.(water lines,heat runs,ect.
Cover assembly attached to post cover
Here's pic of FR round tube (top) and new post cover hose holder (bottom). Rhinoflex is stored in pvc rain gutter. You will have to make a support for the capped end of the post cover.
Installed and ready to use.
C.B.
cbvp is offline   Reply With Quote
Old 04-21-2014, 01:53 PM   #14
That would be the one I remembered... and still a work of art.
Mike Dropped
Old 04-21-2014, 08:50 PM   #15
Sewhappy's Avatar
Thanks for the info. That makes sense. I will show the pics to my DH.
Old 04-21-2014, 09:39 PM   #16
edt
I you are in the area of North west Ga I don't need fence post with cottage let me know
edt is offline   Reply With Quote
Old 04-23-2014, 05:30 AM   #17
Sewhappy's Avatar
Thanks EDT but we are in NC.
Old 06-25-2014, 07:28 PM   #18
I took a coarse file/rasp and filed down the "knobs" to fit inside the back bumper.......J
Jim in Halifax is offline   Reply With Quote
