Originally Posted by Doug Currie
The panels are easy to remove. Just undo the screws and slide last 2 out the back. The next 2 can be removed by also undoing screws and the are flexible enough to pop out one side then slide out side of trailer. The very front one on mine was screwed from above so I just dropped the back of it. The big trick is getting the insulation blanket and foil back in neatly. I can tell you how I did it if your interested.
I want to check/replace the black water valve on a 33IK. I figured out the panel removal, but would like to know how you handle the foil. Did you find a brand or type of tape to seal it back up? Thanks!
