Old 03-12-2016, 07:03 PM   #11
not that hard in the end
Originally Posted by spawnman View Post
I need to restring most of the blinds in my trailer and was wondering if anyone could share how they removed the blinds to be able to do this? Seems very tight and hard to get under the valance to remove them.
Any guidance would be appreciated.
Greg
You first should get the valance out of the way, look up inside there are about 4 Phillips screws you will need to remove, then you will see all the remaining screws to remove the blind.
Now for the blinds if you have the patience anyone can restring their own blinds, BUT if you want look on the bottom of the blind and you will see the company who makes them with a phone # and you can mail back as many as you need redone and the company will do it for a nominal fee, Just saying.
As for WHY you had such a issue with what seems a large number of shades is the fault of FR, they pull the strings WAY to tight in the factory and it wears out the strings VERY FAST. When you reinstall them you only need a small amount of tension under the mounting screw, instead the factory pulls them very tight (thinking them will not fall during transit) I found this out myself after getting a few sets of my own back from the blind company and they sent with them instructions to "reinstall" the tension on the strings and i have not had any problem with the falling or wearing out anymore.
Good luck and i hope this helps and Happy Camping
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
silverback 35ts is offline   Reply With Quote
Old 03-13-2016, 08:30 AM   #12
Greg
What YEAR/MAKE/MODEL????
Our 2014 CC----You have to remove valances.J
Jim in Halifax is offline   Reply With Quote
Old 03-13-2016, 09:15 AM   #13
kinzoo's Avatar
Originally Posted by bob caldwell View Post
Attachment 101755
Sent from my XT1080 using Tapatalk
This is how mine are installed...
Just a example of the shortcuts that Cedar Creek takes to save money...
No consideration for the consumer down the road.
What would be wrong with installing clips to mount these blinds for easy removal and repair.
It would probably take them a minute longer to install clips and do it the right way.
kinzoo is offline   Reply With Quote
Old 03-14-2016, 07:10 AM   #14
shughey00's Avatar
Huh..well on the older Cedar Creeks they used the clips...now I see why you have to pull the valance on newer ones.
And yes they way overtighten the tension on the cords. Not only does it cause early failure but makes it real tough to raise and lower especially on the real wide blinds.
We finally got rid of them all and went with cordless shades. Then again mine were 11 years old.
shughey00 is offline   Reply With Quote
Old 03-14-2016, 07:34 PM   #15
Cordless shades!
Could you advise where you purchased them?
Truck 2009 GMC 2500 HD,D/A,Ext.Cab,SB,air bags, lift kit, flow gate, etc.
Camper's:John,Angie,Coco & Norris
RV: 2011 Cedar Creek 34RLSA
Past RV's: Misc.tents,V.W.Campers('65,'69) 2012 Arctic Fox 25S.
Camping Day's: 2012:25,2013:27,2014:38,2015:38
Little John is offline   Reply With Quote
Old 03-15-2016, 07:40 AM   #16
Mine is at 2013 Cedar Creek/36CKTS.
I will get up under the valances and see what I need to do to remove them.
Thanks for all of the responses!
Greg
spawnman is offline   Reply With Quote
Old 04-26-2016, 04:32 PM   #17
HeyJude's Avatar
Greg
I just pulled my rear blinds off and restrung them. However, I was able to get mine off without taking off the valance. After redoing the blind I'm thinking I'm going to put new cordless blinds in in the near future instead of restringing all of them.
HeyJude is offline   Reply With Quote
