Old 05-17-2013, 12:03 PM   #1
mike2wheels's Avatar
How to remove TV set
Our Silverback has a Jensen LED or LCD TV in a cabinet above the fireplace in the living room. It hangs on a wall mount bracket in the cabinet. I have pushed and pulled on this tv until I'm blue in the face but can't budge it. I thought it would simply lift off the bracket like the one I installed in the house, but that doesn't work here. Because it's in the cabinet there is no room to reach around behind the set. Short of hooking up the truck and yanking it out through the window, is there a trick I'm missing?
2005 Honda Gold Wing
2010 Dodge 3500 SRW
2013 Cedar Creek Silverback 35FL
mike2wheels is offline   Reply With Quote
Old 05-17-2013, 01:09 PM   #2
T.V. Mount
I also have a Silverback (2013) with a Jensen T.V. Mine is not mounted in a cabinet but to the wall. I assume the brackets are the same. There is an L-bracket on the wall at the top of the T.V. to prevent it from lifting off. Once it is removed a firm hit with your hand at the bottom of the set should free it from the bracket.
lupie989 is offline   Reply With Quote
Old 05-17-2013, 01:29 PM   #3
mjones12's Avatar
My Jensen TV mounts in an entertainment center and releases from its bracket in order to attach it to a factory-installed bracket outside. I haven't tried it yet, but there is a chain on the indoor bracket - sort of like an old lightbulb chain - and you pull that to release the TV. Is there enough room behind the TV for you - or someone with a small arm - to reach back there?
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is online now   Reply With Quote
Old 05-17-2013, 07:06 PM   #4
kc8lvy's Avatar
I have a 2013 Silverback 33rl and I tried and tried to get my tv out of the entertainment center and it would not move. I looked at the back of my tv with my phone in camera movie mode and seen it was just a bracket. I wanted to install a blue ray player so I pushed back slightly and lifted up hard it came loose. After the first time I took it off it seems a little easier now. Since then I have installed a Dish Network receiver also.
I found a pic of your setup and the tv mount looks to be te same as mine.
Good luck to you.
2004 Dodge Ram 2500HD Cummins
2017 Keystone Montana 3820 FK
2009 Harley Davidson Ultra Glide
kc8lvy is offline   Reply With Quote
Old 05-17-2013, 07:10 PM   #5
jevanb's Avatar
I have the same mount and mine came right off this fall
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 05-17-2013, 07:17 PM   #6
kc8lvy's Avatar
Here is a pic of the mount and the back of the tv
Old 05-19-2013, 12:06 AM   #7
Thanks. I needed to put more effort into it. It came out, revealing another pile of sawdust.
2010 Dodge 3500 SRW
