Old 03-12-2019, 08:07 PM   #1
Hydraulic slideout open/close valve issue
Recently one of the the knobs that control the individual movements of the slides on my 2015 silverback 29re came off in my hand. Has anyone successfully re-attached one of these knobs? Or upgraded to a more substantial method.
Use the system frequently when cleaning/loading etc.
WyomingJack
2015 CC Silverback 29 RE
2014 GMC 2500 HD
WyomingJack is offline   Reply With Quote
Old 03-12-2019, 09:11 PM   #2
Jim34RL's Avatar
Yes I have. The knob has a small set screw that secures this to the shaft that controls the slide. I have tightened all of the knob set screws on my trailer. Examine the knob closely and you will see the set screw.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 123K+miles
Old 03-12-2019, 11:17 PM   #3
Thanks Jim for this info. I did not know this as Iím sure many donít. I will check the set screws on mine also. Allen screw or screwdriver?
2016 Siverback 33IK
Old 03-13-2019, 06:44 AM   #4
Thanks, I will look for the set screw later today.
WyomingJack
2014 GMC 2500 HD
Old 03-13-2019, 10:13 AM   #5
Don't over tighten it. I split one of my knobs in halve.
cody1884 is offline   Reply With Quote
Old 03-13-2019, 10:20 AM   #6
Jim34RL's Avatar
It was a couple of years ago that I had to tighten the knobs so, I really don't remember which style I used. Plus my trailer is in storage right now and I can't remove one to tell you.
God Luck.
Jim W.
Old 09-19-2019, 09:40 PM   #7
Boatdude62's Avatar
Any idea for a replacement knob... have one that disappeared?
Boatdude62 is offline   Reply With Quote
Old 09-20-2019, 08:29 AM   #8
kinzoo's Avatar
I found one here at Grainger supply, not sure if this is the correct one.
Do a search on there website for "Pointed Control Knob".
They have a bunch of different ones.
https://www.grainger.com/search?sear...d+Control+Knob
kinzoo is offline   Reply With Quote
hydraulic, slide, valve
