Old 08-22-2014, 06:55 PM   #11
mine worked on my 2013 36CKTS than stopped but I later found out that the water lines on some were not installed correctly and fell off leaking water .
bob34787 is offline   Reply With Quote
Old 08-23-2014, 08:26 AM   #12
I am not seeing any water on the carpet or around the outside. I would think you would. Did you have to pull out the refrigerator to check it? I love the layout of the CKTS, but hate the lack of access panel's. If I drop anything behind the tv it is there to stay. Lol
bt_1959 is offline   Reply With Quote
Old 08-24-2014, 02:29 PM   #13
Hi Wayne, thanks for helping me find where to turn on the ice maker. Click image for larger version
Name:	ImageUploadedByForest River Forums1408908242.419543.jpg
This is a lever. Would this be it?
Name:	ImageUploadedByForest River Forums1408908400.908242.jpg
This is the 2nd option and the white knob seems to screw down. Not a push/pull option.
Both of these are behind back tire drivers side.
Linda
lpritchard is offline   Reply With Quote
Old 08-24-2014, 05:20 PM   #14
The second photo is the one for the ice maker. The first one drains the fresh water tank.
Sterlingsilver is offline   Reply With Quote
Old 08-25-2014, 12:23 PM   #15
Thanks! Will have to take in to be fixed because I can't push or pull it out. So glad at least I know where it is now.
Old 08-25-2014, 12:35 PM   #16
bubbles's Avatar
If you can't get close enough to see the top of the valve can you use a mirror to see if there is instructions indented on the top. That type of valve is typically a push/pull type. Mine is very hard to actuate (push/pull). Maybe not.
Old 08-26-2014, 09:18 PM   #17
Wayne & Kim
Wayne & Kimmy's Avatar
Sorry for the delay in responding - had business meetings and late dinner and drinks at work!
Glad you found the valve ; yep, that 2nd picture was the one -sterlingsilver was spot on. As I recall, it is a push/pull deal, and it needs to be pushed in for it to work. Hard to tell from your pics, but it almost looks like some of that black tubing is in the way. If you have enough play in the line, CAREFULLY make sure they are not blocking each other and then push in firmly on the end of the white knob. Worked like a charm for me afterwards - never a problem running out of ice!
Let us know how it goes. I'm taking the CC out this weekend so I can take another look at things and touch base if need be.
Wayne
Wayne and Kim
2014 Cedar Creek 36CKTS
2011 Ford F250 King Ranch 4x2 Diesel, added springs
Nights camped: 2014 - 32; 2013 - 23
Wayne & Kimmy is offline   Reply With Quote
fridge
