Old 09-20-2016, 11:58 AM   #1
Stevemc's Avatar
Improving A/C performance
I've read several different times about making a small shade out of PVC pipe and cloth to place over your A/C unit to improve the performance in hot weather when someone is having trouble keeping cool. So many of these newer RV's including our Cedar Creek have black A/C covers. I was on the roof the other day checking on something and the A/C covers were so hot in the sun I couldn't hold my hand on them. I wonder if we are sacrificing performance for appearance with these black A/C covers? If it helps the A/C units to be in the shade wouldn't the same hold true for using white covers instead of black?
Has anyone else thought of this? Has anyone tried switching their black covers for white to see if it makes a difference in the cooling performance? Thanks Steve
Steve & Jean
Furbaby - T.J.
Towmotor - 2013 Chevy LT DRW Duramax/Allison
5er - 2013 Cedar Creek 36CKTS Classic Champagne Touring Edition
Stevemc is offline   Reply With Quote
Old 09-20-2016, 12:10 PM   #2
Iwannacamp's Avatar
I suppose if water isn't an issue the best thing you could do in a hot climate is to rig up a single mister near the inlet condenser air...there would be an art to how much is enough and how much is too much. I would think a single mister with no run off would be great. I may do that sometime. I have 2 a/c units on my soon to be 34ish ft OAL little 5er. I don't think I will have any more trouble. This would add to the life of the a/c. I am also going to insulate the cover. I haven't decided exactly what type of insulation yet. My new ones will be black.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Days camped 2016 8 2017 1
Iwannacamp is online now   Reply With Quote
Old 09-20-2016, 12:40 PM   #3
If your a/c coil is clean then it won't matter.
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 09-20-2016, 01:00 PM   #4
Iwannacamp's Avatar
Most A/C units are designed to run at normal ambient max of 95 deg. or approximately 115 deg inlet air. The problem is the roofs(and covers) can be much hotter than that. Most troubles on this forum are in the extreme conditions. 95+ deg. or extreme load conditions. Kids going in and out, r-2 insulation values, 90+ indoor temps at set-up, low air flow and leaking air flow. One doesn't have to look hard to find heat infiltration and loss in an RV.
2017 Puma 297RLSS
Old 09-20-2016, 01:22 PM   #5
Stevemc's Avatar
Yeah I get all the inefficiencies that are inherent in RV's. I just wonder if all the heat that the black covers absorb from the sun are adding to that inefficiency unnecessarily.
Old 09-20-2016, 01:37 PM   #6
jeff
jeff64's Avatar
But of course it does, Steve! Price out replacing all the covers with plain vanilla ones. $
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 09-20-2016, 01:41 PM   #7
SailorSam20500's Avatar
Or get a can of white spray paint for plastic. There is a thread around where this was advocated...
Al
S.E. Mich.
Flagstaff 26FKWS / 2016 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 09-20-2016, 02:01 PM   #8
jeff
jeff64's Avatar
[QUOTE=SailorSam20500;1322307]Or get a can of white spray paint for plastic. There is a thread around where this was advocated...[/QUOTE
I've heard that too, think over that concept for a while. I'll pass on the paint
14K Equalizer
Old 09-20-2016, 02:32 PM   #9
Stevemc's Avatar
Yeah I'm not fond of painting them either. I quick search shows most replacement A/C covers at around $100. Not a bad investment if it makes enough of a difference. I'd like to find someone who's done it to see it it made a significant difference.
Steve & Jean
Furbaby - T.J.
Old 09-20-2016, 02:52 PM   #10
Iwannacamp's Avatar
That is why I am planning insulation under the cover. The common is the reflectit type. Google search shows very low r rating, but IMO any would help. Maybe reflective first and some foam if heat and space allow. That's my plan anyway.
2017 Puma 297RLSS
