Old 11-22-2018, 01:32 PM   #1
sh1pper's Avatar
Inside door handle?
Because I have had doors that a strong wind pulled out of my hand and slammed into the side of the RV, I wonder if someone hasn't found a way to add a handle (I'm using some string that makes a loop) to the to the existing small handle that's hard to grip if a gust of wind hits it? Thanks for any suggestions!
Hugh and Fran
"Riley" the dog
2018 Cedar Creek 38EL Champagne
2017 Ford F350 SRW CC SWB 4x2
Demco Hijacker Autoslide 18k Hitch
sh1pper is offline   Reply With Quote
Old 11-22-2018, 01:38 PM   #2
There is a cross bar that mounts to the door, that can be adjusted for door width. Its held on by 4 screws. It's pretty popular. You should be able to find some pics on here, if nobody post one.
Its made by Camco. Its called a screendoor cross bar.
katkt is offline   Reply With Quote
Old 11-23-2018, 09:08 PM   #3
We did not want to add the full screen door handle, so we bought a 5" drawer handle and put in the center of the screen door. We installed it because it is hard to shut the door when it is fully open but it is also helpful when the wind is trying to jerk the door out of my hand. I made certain that I was buying a handle deep enough that my hand would fit into it and wide enough to grasp.
Lawrence, JD and Bear
2017 Champagne 38EL
Our Rolling Earthquake
Freebirds is offline   Reply With Quote
Old 11-23-2018, 10:13 PM   #4
sh1pper's Avatar
I'm looking for something that attaches to the main door handle not the screen door. A strong wind could separate the screen door from the main door allowing it to hit the side of the RV while the screen door stayed closed.
Hugh and Fran
"Riley" the dog
door
