Old 08-14-2018, 06:02 PM   #1
David17fq's Avatar
Installing a hardwired Progressive EMS. Need advice
Hi all, I'm installing a Progressive Industries EMS-LCHW50 Hardwired RV Surge and Electrical Protector in my 2017 Hathaway 36CKTS. My questions are (1) where does everyone locate it, (2) is there enough slack in the supply line from the 50 amp receptacle to the converter, (3) any advise or suggestions are appreciated.
Thanks!
David17fq is offline   Reply With Quote
Old 08-14-2018, 06:19 PM   #2
Thanks!
That's where i installed mine. Different trailer but i had room behind my converter and just got a short piece of 3 conductor and spliced it in the ems.
2018 Rockwood GeoPro 19FBS
2016 Chevy Silverado 1500 4x4
wevitt is offline   Reply With Quote
Old 08-14-2018, 07:46 PM   #3
David17fq's Avatar
Anyone with a 36CKTS? I was thinking of installing it in the garage near the opening for the central vac.....
David, Tina and our 4 legged daughter Ellie
2004 Chevrolet 3500 DRW Duramax (Jethro)
2017 Cedar Creek Hathaway 36CKTS (Jane Hathaway)
Previously:
2017 Grand Design Imagine 2650RK
2016 Forest River Clipper 17FQ
Old 08-14-2018, 08:27 PM   #4
I have a tt, i removed circuit breaker panel and installed it behind there. Disconnected the feed from panel wired it directly to ems, ran #6 wire from ems back to panel. Reinstalled panel. You have to run #6 wire for the 50 amp ems.
cmysstailights is offline   Reply With Quote
Old 08-14-2018, 09:02 PM   #5
Thanks!
I'm happy for you, our EMS-HW30C is supposed to be delivered tomorrow, ... very anxious to get it and get it installed, ... DW says I enjoy doing things like this to our Micro Lite so much, it's like an early Christmas, ... hope your install goes well, ... happy camping
fella10 is offline   Reply With Quote
Old 08-14-2018, 09:36 PM   #6
Bluepill's Avatar
Don't forget to carry appropriate wires as jumpers to bypass the EMS if it fails. It does sometimes happen, and you are stuck with no power otherwise.
2018 Coachmen Freedom Express 192RBS
Old 08-14-2018, 09:46 PM   #7
Or....another member wired the unit in using extension cord ends so that if a major surge ever cooked the EMS one could simply unplug the cable ends from the EMS and connect them together.
pjnlorrie is offline   Reply With Quote
Old 08-14-2018, 10:56 PM   #8
Jayhawker
Jayhawker's Avatar
I have the 30 amp installed in my TT behind the inverter/panel. I carry a 4 inch square junction box and 2 romex connectors and wire nuts with me in case the unit fails. With the 50 amp you might want the larger junction box a 4 11/16". Also you should know that the Progressive surge guard will not work with an inverter type generator. At least that is what I have been told.
Jayhawker is offline   Reply With Quote
Old 08-14-2018, 11:57 PM   #9
You can put together an “Edison plug” to get past the inverter gen issue. Super simple fix.
Hurseyc is offline   Reply With Quote
Old 08-15-2018, 12:38 AM   #10
I have a 2014 Ckts , I put mine behind the furnace cover to the left of the the fuse panel plenty of room to work the hard part was bending the cables into the ems , I also used the remote display in the basement, it lets me know if the power is alright
Big Bill is offline   Reply With Quote
