Old 04-05-2015, 05:28 PM   #21
I could not figure it out, I took the battery cables loose and charged the battery's with a 40amp charger and when I hooked the battery's back up I still got a error code. That's when I started to look and all four batteries were not hooked up, not to gather anyway.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 04-05-2015, 07:29 PM   #22
Blackhat6mike's Avatar
I think I would have a talk with someone!!!
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 04-05-2015, 07:30 PM   #23
Yep. I've already sent an email to Jeff at Cedar Creek this morning. I'll here from him tomorrow.
2015 Cedar Creek 36 CKTS
2016 Ford F350 DRW
2016 Harley Davidson Ultra Classic Low
rick03hd is offline   Reply With Quote
Old 04-05-2015, 07:58 PM   #24
I hooked the batteries up right and the inverter works. You might Google the 12 volt side of life, I think that's it, anyway it's just like the diagram says on the camper. If the batteries are hooked up in series but not parallel then you have two 12 volt batteries, when hooked up in parallel you have one 12 volt battery with four six volt batteries. Tom Johnson told me first to look behind the bulkhead and disconnect the red wire and leave it off for ten seconds and then connect the red wire back and the inverter would reset itself but it would not because without the batteries being hooked up in parallel the series the inverter was hooked up to was not being charged. When everything is hooked up right what you really have is one big 12 volt battery
Old 04-05-2015, 08:16 PM   #25
One important thing when you hook the series up in parallel to make 12 volt hook up the hot or plus side first then the negative side, that way no sparks or short
Old 04-05-2015, 08:17 PM   #26
Ok. Thanks
2016 Ford F350 DRW
Old 04-05-2015, 09:42 PM   #27
WestCoastRV'er's Avatar
I would put a cut-off switch:
Battery -> inverter
Battery -> rv power distribution system
Solar Panels -> Charge Controller
This would eliminate any possible damage while making connections
2011 2902ss Rockwood Ultralight
2008 Grand Cherokee 3.0L Diesel (255 hp @ 2900 rpm / 430 lb-ft @ 1,400-2,800 rpm)
3P ProPride Hitch
RV Mods
Wandering RV Life
WestCoastRV'er is offline   Reply With Quote
Old 04-05-2015, 09:50 PM   #28
Just curious, why did you disconnect the batts to charge them??
Old 04-06-2015, 05:05 AM   #29
I thought the batteries had got to weak and I had a nice battery charger that I could hook them up too and put life back in the batteries.
Old 04-06-2015, 07:11 AM   #30
yes the batteries are hooked up by the dealer .but they all don't know what they are doing.had mine back 3 times to get it fixed. then had to do it myself.
wire1946 is offline   Reply With Quote
inverter
