Old 04-06-2015, 01:15 PM   #31
Per Jeff at Cedar Creek.
The inverter is bad. He is sending me a new one.
2015 Cedar Creek 36 CKTS
2016 Ford F350 DRW
2016 Harley Davidson Ultra Classic Low
rick03hd is offline   Reply With Quote
Old 04-06-2015, 01:59 PM   #32
how did he figure that out?
wire1946 is offline   Reply With Quote
Old 04-06-2015, 02:00 PM   #33
I gave him the error code. He looked the code up.
2016 Ford F350 DRW
Old 04-06-2015, 02:04 PM   #34
ok
Old 04-06-2015, 02:10 PM   #35
On the older converters the E04 code meant low input voltage. On the new ones it is an internal issue that requires replacement.
Jeff the man I talk with at Cedar Creek really knows his stuff.
2016 Ford F350 DRW
Old 04-06-2015, 02:34 PM   #36
I was talking to him today about a front cap issue
Old 04-06-2015, 03:58 PM   #37
On my inverter I got error E04 but when I took the cable off the E04 code went away and later the error code E02 came on but when I hooked the batteries right the error code E02 went away
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 04-06-2015, 07:58 PM   #38
ttanous's Avatar
Interesting. I received a low voltage on mine this past weekend. I have a digital metered installed in the bay which showed 13.6 volts and the inverter read low voltage. Worked fine and showed 112 volts. Guess I need to look for an error code. When we picked up the coach on December 31st the dealer had to replace the inverter due to being faulty. Might have another faulty inverter.
Tom & Marilyn
2013 Chevrolet Duramax 3500 HD LTZ Crew Cab Long Bed Z71 4X4
2015 Cedar Creek 38RD Hathaway Edition
ttanous is offline   Reply With Quote
Old 04-06-2015, 10:48 PM   #39
97flhtcui's Avatar
On ours the dealer when they installed the batteries, they hooked up in series but failed to hook up in parallel. Facing the batteries. The 2 on the left read 6.5 volts each the 2 on the left read 5.3 volts each. The 5.3 v batteries. Were the ones they had the inverter hooked up to. The fully charged were hooked up to the converter. The dealers tech hooked them up at pdi and took hime 4 hrs. He didn't. Know what he was doing.
2011 Ford F-250 6.2l gas 373 rear end
2015 Cedar Creek 34RL
MORryde IS 7000 LB
Kodiak Disc Brakes
97flhtcui is offline   Reply With Quote
Old 04-07-2015, 12:32 PM   #40
I have heard many stories of dealers who don't know how to correctly configure the batteries
2016 Ford F350 DRW
inverter
