Old 04-08-2015, 09:55 PM   #41
The diagram for the 4 batt setup doesn't provide any charge to the batteries that the inverter runs off of you need to wire the two sides together so they all charge
jared.stoltzfusrvs is offline   Reply With Quote
Old 04-09-2015, 09:14 AM   #42
The diagram on my Cedar Creek does show how the batteries should be hooked up, how someone can mess it up is beyond me. Click image for larger version
Name:	ImageUploadedByForest River Forums1428588848.530372.jpg
ID:	73606Click image for larger version
Name:	ImageUploadedByForest River Forums1428588883.680604.jpg
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 04-09-2015, 09:34 AM   #43
I under stand that but the main battery cables are not connected like shown Click image for larger version
Name:	ImageUploadedByForest River Forums1428589804.786559.jpg
ID:	73608Click image for larger version
Name:	ImageUploadedByForest River Forums1428589827.828933.jpg
ID:	73609Click image for larger version
Name:	ImageUploadedByForest River Forums1428589861.061903.jpg
ID:	73610Click image for larger version
Name:	ImageUploadedByForest River Forums1428589910.187057.jpg
The diagram has you basically wire up 4 6 volt batteries to make to large 12volts. But the main poss cables do not connect together like the diagram shows as you can see in the last pic I posted the 2 red wires coming through the back of the batt box one feeds inverter only and 1 feeds rest of coach.
Old 04-09-2015, 10:36 AM   #44
I have C.C. too and mine were not hooked up right. when plugged into truck didn't charge .so the dealer needs to be schooled in battery connections. also I moved my batteries to the right so I could get at them .put a automatic full tube on them.
wire1946 is offline   Reply With Quote
Old 04-09-2015, 10:43 AM   #45
The pics I posted are from one I just peeped and that's the way it should be done so all 4 batteries get charged .
Old 04-09-2015, 01:57 PM   #46
I under stand that but the main battery cables are not connected like shown Attachment 73608Attachment 73609Attachment 73610Attachment 73611
I have the same hookup, when you have just one large 12 volt battery it doesn't matter which hot post you hook up too for your inverter or the coach. I put the inverter and the coach on the same hot post but you can put them on different posts, I don't think it matters, first you have to get the batteries hooked up right. I have used disconnects like these but then I have to check them about ten times just to make sure I have everything hooked up right because you can mess something up real bad when you throw the switch. Next year I want to set up another battery bank just for the coach, with Trojan six volt, four battery bank. Click image for larger version
Name:	ImageUploadedByForest River Forums1428605625.231920.jpg
ID:	73638Click image for larger version
Name:	ImageUploadedByForest River Forums1428605649.829041.jpg
ID:	73639Click image for larger version
Name:	ImageUploadedByForest River Forums1428605683.128912.jpg
ID:	73640Click image for larger version
Name:	ImageUploadedByForest River Forums1428605790.679542.jpg
Old 04-09-2015, 04:13 PM   #47
Both leads coming into box are Not connected behind the box they must be hooked up to the same lead or jumped together
Old 04-09-2015, 07:40 PM   #48
This diagram shows the missing wire we had -and many other rigs we have looked at have had the same missing wire to group the two sets of batteries into a complete parallel/serial group.
And to clarify - we have jumpers across all four batteries BEFORE they connect to the coach and inverter so all four are supplying the coach and inverter.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 04-09-2015, 07:44 PM   #49
Blackhat6mike's Avatar
My inverter cost me $1,000. You guys are scaring me!!!
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 04-10-2015, 07:29 AM   #50
Attachment 73667
Just go to 12 volt side of life and hook your battery bank like it shows in his diagram and you will not go wrong, if I can do it anyone can do it. I know it looks confusing but it's not, you can hookup the inverter and the coach to the same hot post and then hook up the ground to the ground post. It does not matter which post you use on which battery because with the batteries hooked up in series and parallel you have is one large 12 volt battery, when hooked in parallel all the batteries will charge
inverter
