Old 10-13-2013, 08:23 PM   #1
Inverter Fan running with unit shut off
I have a 2013 Cedar Creek Model 38RE with a Xantrex XM 1800 Inverter. It is hooked up to shore power and the unit is shut off. The fan comes on and runs intermittently. Is it normal to do this?
gsmall is offline   Reply With Quote
Old 10-13-2013, 09:08 PM   #2
Denver, CO
garbonz's Avatar
check if the charger portion of the unit is also shut off, if it is a inverter/charger. the model you have doesn't appear to be a charger, but that is what would cause that sort of behavior.
otherwise check the output voltage to see if it is really shut OFF.
2017 Fuse 23T
Old 10-15-2013, 06:52 PM   #3
The unit is off. There is no display on it. No output voltage. There is a battery switch located between the inverter and the batteries.
With the battery switch turned off, the fan does not run. Without the shore power hooked up, the unit appears to work OK. The display shows battery voltage and output voltage.
Don't know if the battery switch should be off or not and technically speaking I would think that it shouldn't matter.
Old 10-15-2013, 07:10 PM   #4
Former Full Timer
Duckogram's Avatar
Something is not adding up. The battery switch? Is that the battery disconnect switch located in your docking station? The fan is running. Do you just hear a fan or do you see the fan on the Inverter spinning? Sorry for all the Q's with no A's
The reason I'm asking is that the AC shore power is supposed to "pass through" when the switch is off.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
fan, inverter
