Old 11-30-2015, 11:28 AM   #21
did get a call back from Sensata and this unit will not charge battery. So now off to hunt the converter.
Thanks for the info agin
Joe Wakeman
2012 36RE
2013 2500HD Duramax
jwakeman is offline   Reply With Quote
Old 11-30-2015, 11:37 AM   #22
AquaMan's Avatar
Pull the fuse panel from the wall, it's most likely laying just behind it. May also be able to pull a panel from your basement and access it there also. I was able to see mine in my Sierra by pulling the fuse panel, but had better access by pulling a panel off in the basement.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 12-01-2015, 05:20 PM   #23
Thanks to all for the info and clarifications. I found the converter box in a vary out of the way place. Found a test procedure that show 12.2 in and 9.5 out. replacement ordered now need to find a small person to install.
Joe Wakeman
2012 36RE
2013 2500HD Duramax
Old 12-01-2015, 05:40 PM   #24
AquaMan's Avatar
Did you go with a Progressive Dynamics unit? They cost a little more, but well worth the money if you are replacing anyway. The WFCO's will fail sooner or later.
inverter
