11-24-2017, 10:07 PM
Is it okay to make refrigerator unlevel
We have had our Champagne for two months. Four times we have discovered we did not shut the refrigerator drawer completely which allowed the temperature to reach thawing levels. Never had a problem with two doors.
This is strictly "operator error" but still we have erred and almost lost a freezer full of food. Would it do any harm to raise the front two legs higher than the back? This is, of course, a residential fridge so it doesn't have to be level, right?
Lawrence, JD and Bear
2017 Champagne 38EL
Our Rolling Earthquake
11-24-2017, 11:09 PM
If it was in your home wouldn't you adjust the front slightly higher so the doors would always tend to close? Why not.
11-24-2017, 11:16 PM
Canadian Member
I’m not sure about residential fridges needing to be level but they typically are level in homes, or maybe slightly high in the front, but I suggest that you would benefit from having a departure checklist and using it every time. I use an app called “RV Checklist”.
You might want to get one of these, too:
https://www.bedbathandbeyond.com/sto...rts/1040496481
Has high temp alarms.
2011 Traverse LT, 3.6L, FWD
11-24-2017, 11:23 PM
The alarm system sounds like a great idea. I will buy one to go along with slightly raised legs.
This is not something we do for travel. It is an ongoing battle to make sure that drawer is closed.
Thanks for the responses.
2017 Champagne 38EL
11-25-2017, 09:42 AM
Just a few degrees for door closure, yes.
11-25-2017, 09:53 AM
Residential fridges and evaporative fridges are very different animals. You will be fine with a residential fridge that is not perfectly level.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
11-25-2017, 09:57 AM
Isn't there some type of device that locks the doors and drawer closed during travel?
I use a strap for my residential refrigerator and as others also use some type of strap or device to hold them close.
I would look into something like that to insure they remain closed during travel. I purchased a strap for less than $22. which included taxes and shipping from Tiara RV Sales.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
11-25-2017, 04:28 PM
Rv refrigerators are absorbers. Both compressor type and absorber types fridges have a process of evaporation, this is what cools the space / food. Absorbers use no mechanical means to move the refrigerant but a chemical reaction due to boiling the chemical solution of pure water and ammonia and hydrogen gas. The flow is dependent on gravity to properly return to solution reservoir and reconstitute the refrigerant mix. Not leveling this type is a recipe for disaster.
Home refrigerators use compressors to move the refrigerant through the system and does not use gravity for nothing other than the condensation drain
2018 sunseeker 2860DS
11-25-2017, 10:50 PM
I'm no expert when it comes to ammonia refrigerators but would a few degrees off front to back really have a negative impact? I could understand side to side but even just a few degrees?
2016 Sunseeker 2400WM Sprinter 3500 Diesel
11-25-2017, 11:06 PM
My regular old RV fridge has cooled perfectly being more than a few degrees off level. We overnight hooked up and unleveled during long trips. Some were really unlevel both ways. I've always said as long as you can walk around your rig upright, the fridge is ok. Don't understand this myth that your fridge won't work and will be damaged if you aren't perfectly level. RL experience says that just isn't so.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
11-26-2017, 09:15 AM
Not trying to be a Smart *****,,,
but I would teach myself & my family to close the door !!!
11-26-2017, 09:41 AM
Out of level a little isn't bad. The fridge will work and for the most part have no issues. When the ammonia can't reconstitute with the water and the water itself starts to boil the sodium chromate when continued heating will solidify and block flow. Also once the water is separated from the ammonia and not able to return to solution the water will attack the steel tubing etc. the excess heat will make stress areas brittle and possibly crack welds etc. check out this explanation at this web page.
The RV Doctor: RV Absorption Refrigeration Basics
11-26-2017, 04:28 PM
“Since the absorption system utilizes no
mechanical pumps or compressors to circulate the refrigerant within the system, proper leveling is required to provide correct refrigerant flow in the gravity-feed system. Without proper leveling, refrigerant within the cooling coils will collect and stagnate at certain areas. When this happens the cooling process will stop.
(17)
On the older style cooling units equipped with square boiler box covers, this condition can cause permanent cooling unit failure. As we can see from this drawing, square boiler box cooling units utilize an exposed siphon pump tube which will become excessively super- heated in an out-of-level condition. This can allow the rust inhibiting agent to chemically break down and permanently block or restrict the normal refrigerant flow through the pump. Shaking, tipping or so called ‘burping the refrigerator will not loosen or dislodge the blockage. The only recommended service procedure is to replace the cooling unit. To prevent this occurrence, proper leveling is of utmost importance when the RV is parked for
any length of time.”
Written by a Dometic eng. maybe 20 years ago. The boiler problem was corrected but performance is still hampered when out of level.
11-26-2017, 08:54 PM
Canadian Member
Several posts here have been about RV refrigerators (LPG/AC). The OP has a residential refrigerator with a compressor.
11-26-2017, 09:17 PM
Originally Posted by rockfordroo
X2 - have used this for years.
Mike and JoAnne
Montana Summer / Arizona Winter
2016 Prism 24G /2002 HitchHiker 38LKTG
ACME EZTowing a 2015 Chevy Sonic RS Hatchback
11-27-2017, 12:08 AM
And? Threads diverge. Try to keep up.
11-27-2017, 08:27 PM
LOL You are so right! The problem is we get busy cooking and give the drawer a shove and bingo - it is not totally closed. This is not something we do daily but it is not good to even do it weekly. We have always had refrigerators with doors so it is a new experience.
We do plan to buy the temperature sensor.
To those who replied concerning being in transport - there is no problem there. We have a child lock on it - then velcro strap - then a cord. Drawer or doors cannot move.
Thanks for all who replied.
2017 Champagne 38EL
