Old 04-16-2015, 11:03 AM   #21
Originally Posted by Jim34RL View Post
I have a question on this could you not use a sound bar for the TV sound only portion? Also does the Jensen TV have a optical digital audio output for the TV?
We have on order a 34RL and we just received the Vin # so I will be able to check this out soon to see if my idea will work? I also had the dealer install a MORryde TV mounting bracket (TV1-006) for the TV; so we can swivel the TV for better viewing from the theater seating.
Thanks foyour help in advance.
No mine doesn't have an Optical digital output, But I have my beltone link 2 hooked to my audio out and my suround sound hooked there too, with a spliter. Works great! Don't forget Jensen Tech support will help also. Good Luck
saltlake is offline   Reply With Quote
Old 04-17-2015, 04:44 PM   #22
Here is the solution from Jensen tech:
Thank you for contacting ASA Electronics. Try choosing the AUX mode. Typically the OEM will connect and use the AUX inputs on the radio to play the Audio through the stereo system. If it is not activating, check your TV Menu, under Audio, turn your TV speakers OFF and try again.
Let me know how this goes. Here is a link to the manual for reference. http://www.jensenrvdirect.com/downlo...rs_manuals.pdf
Thank you for allowing us to assist you today!
Technical Service, ASA Electronics
Lon Ancheta
Bbbarker194 is offline   Reply With Quote
Old 04-19-2015, 09:26 AM   #23
HeyJude's Avatar
We had the same problem in our 2011 29rl. Dish came out yesterday to adjust our satellite and we asked the technician about the lack of sound. He ended up selling us a great sound bar. I'm very hard of hearing and now I can follow a movie without too much thought. Hope you get it resolved!
HeyJude is offline   Reply With Quote
Old 04-19-2015, 10:14 AM   #24
My issue is resolved. I solved the problem by following the instructions from ASA Electronics using the AUX mode on the stereo. Works great!
Old 04-19-2015, 07:11 PM   #25
Like I said!
glfillion is offline   Reply With Quote
jensen
