Old 09-30-2016, 09:39 PM   #21
camaraderie's Avatar
Originally Posted by markb422 View Post
Check the specs on your receiver. Most cable boxes only output 720p so the hdmi cable is wasted on it anyway. My direct tv and blue ray player will output 1080p and warrant using the hdmi. The component outputs is all the 720p output needs.
You have a misunderstanding of the nature of HDMI v. Component. BOTH are perfectly capable (or not) of providing full resolution HD from source to display. This article should clarify the differences if you're interested.
https://www.bluejeanscable.com/artic...icomponent.htm
In my view, the only discernible difference over short distances is the convenience of a single connection.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 10-01-2016, 07:30 AM   #22
DouglasReid's Avatar
Originally Posted by KenInCA View Post
Right, Spock. I connected a coaxial cable from the Satellite connector on the wall to the back of the DISH receiver. That's one connection. From the HDMI port on the back of the DISH receiver, I connected an HDMI cable to the television's HDMI input. That's the second connection. And...I was getting DISH programming.
With the one HDMI input now taken up on the back of the television, how do I get a cable television connection? I guess I could use the component RCA cables (red, green, blue, yellow) to connect the DISH box to the television but that seems like a huge hassle.
If the television had two or more HDMI inputs, there would be no connection issues.
Anyhoo...we're enjoying our Cedar Creek so far!
Im just curious, if you have a Dish connected and programming, why do you also want to hook up cable TV? It seems to me one duplicates the other.
That being said, have you tried using a splitter where the cable and/or dish connects to the outside of the camper. You could then hook up both input cables to there. You can't watch both but by turning on only one receiver at a time, you would have both options
Maurice, LA
2012 Wildcat Sterling 32RL
2008 Chevy Silverado 2500HD LT Diesel
TST TPMS system w/ Flow-thru sensors
2001 Cougar 281 EFS (sold)
DouglasReid is online now   Reply With Quote
Old 10-01-2016, 07:37 AM   #23
If the issue is not enough HDMI inputs...heres a 3 in...1 out switch.
Dynex 3-Port HDMI Switch Black DX-HZ325 - Best Buy
________
Cam
Old 10-01-2016, 08:45 AM   #24
Hi, I have a 2016 34RL with Jenson tv, I hooked up a Blu-ray player and a DirecTv receiver (used HDMI splitter) in the cabinet left of the fireplace. Used the HDMI port in the cabinet and power in the rear of the cabinet. There are 2 HDMI ports on the TV, already hooked up with the Jensen multi entertainment center in HDMI1 and the Cabinet port as HDMI 2. I had to add a coax cable to run from the satellite outlet behind the Jensen TV to the DirecTv box in the cabinet. Just drilled a small hole into the fireplace cavity.
HDMI 1 port is on the back and HDMI 2 is on the left side
timerie is offline   Reply With Quote
jensen
