09-29-2016, 06:04 PM
Jensen TV...Only one HDMI Input?
My wife and I recently bought a 2017 Cedar Creek Hathaway Edition 34RL. We wanted to hook-up our DISH receiver. For a good 10 minutes of effort we wrestled the living room television off its mount. The HDMI input cable for cable television was attached to the Jensen television as expected. We searched for an additional HDMI input to connect the DISH HDMI cable to the back of the television. We could not find an additional HDMI port. The on-screen input selection has options for HDMI 1 and HDMI 2.
Did we just miss the other HDMI inputs, or is this a situation that others have encountered on the Jensen television(s)?
Interestingly, in the cabinet next to the fireplace, another HDMI input connector was discovered. I tried hooking up DVD player to this port but could not see any visual connection on the television at any of the HDMI options.
Before placing the television back on its mount, I connected the DISH box to the single HDMI input port and was able to get DISH programming.
If anyone has discovered additional HDMI ports on the Jensen TV, please let us know.
Ken & Lucy
09-29-2016, 06:18 PM
I don't know about your model tv, I can only suggest, ..... often, if there are only two HDMI ports, with one on the back,........ the other will be located on the side, with other buttons like on/off, volume, ect.
09-29-2016, 06:23 PM
side connectors
Thank you for the suggestion, Fella.
In my previous 5th wheel, the Sansui television(s) did have side HDMI ports. I didn't see any HDMIs on the side, but I did see component RCA connectors which I could use in a pinch.
Ken
09-29-2016, 06:30 PM
If you look where the Dish receiver sits at there is a HDMI cable or a place to hook it up at. I have a 32RL Cedar Creek and my Direct HDMI cable is a connection
09-29-2016, 09:22 PM
Right, Spock. I connected a coaxial cable from the Satellite connector on the wall to the back of the DISH receiver. That's one connection. From the HDMI port on the back of the DISH receiver, I connected an HDMI cable to the television's HDMI input. That's the second connection. And...I was getting DISH programming.
With the one HDMI input now taken up on the back of the television, how do I get a cable television connection? I guess I could use the component RCA cables (red, green, blue, yellow) to connect the DISH box to the television but that seems like a huge hassle.
If the television had two or more HDMI inputs, there would be no connection issues.
Anyhoo...we're enjoying our Cedar Creek so far!
09-29-2016, 10:24 PM
On the wall in my Silverback and all my previous RV's I had 2 coax connections on the wall and 2 coax connections outside. One is labeled cable and one is labeled satellite. So are you saying you only have one coax connection on the wall behind your tv? You should (?) have 2 coax connections of which one you have connected to you Sat box and then HDMI to tv. The other coax should just connect to the coax connection on the back of the tv. Cable tv in campgrounds is not HDMI. It is digital but delivered via coax.
09-29-2016, 10:28 PM
In my first post I neglected to ask if you are full time somewhere and using a cable box from a cable provider? In that case you will need to use the rgb connections or usually a cable box also has a coax out.
09-29-2016, 10:55 PM
I see what you're saying, Dalford. I'll have to go look in my RV tomorrow since it's at a storage facility right now. My previous 5th wheel had the setup that you're describing. Both my wife and I think there was just one coax connection behind the television. I hope we're wrong.
The outside connector box has three coax inputs. One is for cable tv and the other two are for a living room satellite and a bedroom satellite hookups.
No we're not full timing anywhere. We're nomadic.
Thanks for your suggestion. We're hoping you've solved this minor situation!
09-30-2016, 07:13 AM
I don't have a problem when I hook up to cable, I hook that up on the outside I can have cable, satellite, and over the air tv. If I want to hook up my portable satellite dish then I have to change some cables. I have a Trav'ler on top of camper plus I can hook up my portable satellite dish
09-30-2016, 07:54 AM
If you do not have the manual for the TV, post the model number and I'm sure we can find you a copy. It will tell you where the HDMI inputs are.
09-30-2016, 08:54 AM
We ran the HDMI out of the 211Z into the TV and ran RCA jacks to the DVD/stereo, haven't had an issue. We ran RCA audio from the 211 into the back of the stereo and have the ability to run the TV sound through the stereo.
We did this because we mostly watch the satellite and wanted the best picture from it.
Former Owner of
2016 Cedar Creek 36 POS (My Last FR Product)
09-30-2016, 09:01 AM
My son brought me Apple TV a couple years ago and I have Direct tv at home, I have a nice Sony tv but guess what it has, only one HDMI slot
09-30-2016, 09:04 AM
Go to this site and enter your TV model number you should find your operating manual on this site.
Manuals & Guides
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
09-30-2016, 09:07 AM
My biggest gripe is I can't program my Dish remote to run the TV.
Former Owner of
09-30-2016, 10:34 AM
Haven't yet found a TV with remote capability that you can't program the remote to. Find your list of codes and try them, and if they don't work look up how to do the manual method. All the codes/instructions are online also. You can do it!! 😁
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
09-30-2016, 11:19 AM
Tried all that last year with no luck, might be time for another go at it.
According to FR (2015) Jensen does not release the codes for the remotes.
Former Owner of
09-30-2016, 11:56 AM
Google search found these in 0.03 seconds.
JENSEN codes 3 digit:
004
009
Newer JENSEN codes 4 digit:
0004
0009
0133
09-30-2016, 12:43 PM
004
009
0004
0009
0133
Thank You, I'll try those
Former Owner of
09-30-2016, 04:36 PM
Ken & Lucy
Ken...absent a model #, your spec sheet says a 48" TV and the Jensen 4815 is the only one I can find on line...it shows HDMI ports on the bottom of the TV...towards the rear. Along with the headphone jack and USB port. Dunno if that is the right one...but hope it works for you. Looks like Jensen/ASA is no longer in the TV business as all their pages have been killed.
________
Cam
2015 Georgetown 280DS
09-30-2016, 09:19 PM
cable connect
Check the specs on your receiver. Most cable boxes only output 720p so the hdmi cable is wasted on it anyway. My direct tv and blue ray player will output 1080p and warrant using the hdmi. The component outputs is all the 720p output needs.
