Old 08-09-2016, 12:02 PM   #51
dgibbs1955
dgibbs1955's Avatar
Just put Michelin Ribs on CC 34RLSA
I put on 4 Michelin LT 235/85/R16's Load Range E and just did a 5,000 trip this summer and had no problems with them the entire time. Saw too many rigs on the side of the road this year with tire problems. Do not trust the ST tires....
2012 Dodge 3500 Cummins Crew Cab 4X4, "Decluttered" and Tuned/2013 Forrest River Viper XLR 390V10 Toy Hauler/2012 Harley Davidson Ultra Glide CVO.
Full time RVer.
dgibbs1955 is offline   Reply With Quote
Old 08-09-2016, 12:16 PM   #52
Av8orLou's Avatar
Thanks for sharing your experience. I have the same tires on mine now
2015 GMC Denali HD Z71 4X4 - D/A
2004.5 Chevy D/A
2013 Cedar Creek 34rlsa
2003 Four Winns Funship 214 Deckboat - Hawaiian Breeze
Av8orLou is offline   Reply With Quote
Old 08-09-2016, 02:29 PM   #53
Airdale's Avatar
http://www.discounttire.com/dtcs/infoSelectRightTire.do
Help Me Choose The Right Tire | How to choose tires | Michelin US
USN - RET - PDRL
DOD - RET - Journeyman Aircraft Mechanic
SSA - RET
Airdale is online now   Reply With Quote
Old 08-09-2016, 02:55 PM   #54
Airdale's Avatar
Suitable replacements for the ST235/80R16E OEM tires on RV trailers.
ST235/85R16E - 3640# of load capacity at 80 PSI
LT235/85R16G - RST - 3750# of load capacity at 110 PSI
ST235/85R16F - 3960# of load capacity at 95 PSI
ST235/80R16G - 4080# of load capacity at 110 PSI
205/75R17.5 LRF - 3525# of load capacity at 109 PSI
215/75R17.5 LRF - 3530# of load capacity at 100 PSI
215/75R17.5 LRH - 4805# of load capacity at 125 PSI
There are others but those above are very close on overall diameter and section width of the ST235/80R16E
You should always ask your trailer’s manufacturer about replacements before you go out on the limb all by yourself.
USN - RET - PDRL
SSA - RET
Old 08-09-2016, 10:02 PM   #55
Lots of talk about different brands. How many of you have your wheels balanced? I feel that balancing is every bit as important as tire pressure and brand. My 2 cents.
ba964 is online now   Reply With Quote
Old 08-09-2016, 10:37 PM   #56
NMWildcat's Avatar
I can't imagine anybody having a tire mounted on any high speed application without balancing, or a tire shop not insisting on it. We probably don't talk about it as we feel it's a given? But you do make a good point.
Scott and Liz - Southern NM
Old 08-10-2016, 06:48 AM   #57
Av8orLou's Avatar
Wheel balancing is a requirement of mine
2004.5 Chevy D/A
Old 08-10-2016, 09:40 AM   #58
Does the factory balance the tires? I don't balance my tires on the camper. When I put new tires on the truck they are balanced but not after that. I just rotate the tires
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 08-10-2016, 11:10 AM   #59
NMWildcat's Avatar
My last 2 5vers came with balanced tires. Don't know who did it. Of course I changed them out for LTs when we got 'em home. I rotate and balance tires on the TV every 5 to 10k miles. It's free. I rotate and balance the 5th wheel tires once a year when I repack bearings. I can't imagine only balancing tires once on a TV. I notice the difference in ride in about 8-10k miles after the last balance.
Old 08-10-2016, 02:15 PM   #60
I don't know how to repack the bearings, I have easy lube. My Cedar Creek came with LT tires
