Old 10-01-2016, 06:20 PM   #1
King Dish Installation
So I'm not totally "mechanically" challenged, but I do make mistakes at times. That being said I'm considering purchasing our new fifth wheel with King Dish and two receivers already installed. My thinking is that at $1100 now, I'm spending close to $400.00 more than if I did it myself. But then I get the work warrantied and will not have to worry about extra cable work or roof damage (my biggest fear).
What do think ? Is it really easy to just install the system myself or going with factory install is a good idea ?
DLoree is offline   Reply With Quote
Old 10-01-2016, 09:54 PM   #2
Let me just say, $400 savings is NOT WORTH self learning on that thin membrane roof.
I had a faulty a/c. FR could not do it timely at the factory. ( had other work as well under warranty). My selling dealer ( very small shop) was equidistant in travel. FR recommended an overflow service center in the Topeka area.
During the work, they tore my roof. Used eternabond tape strip right near the A/C install.
Because of travel distance; we agreed on roof replacement after the recent 2016 Rally. And so it has been done.
If YOU undertake this install and cause damage; that will be your responsibility. It would not take much for that dish to rip your roof. Please consider the small savings vs the cost of a new roof!! Make sure if you contract someone; you get a pre inspection signed by both parties that there is no damage present. A POST work completion report releases the installer.
Just say'n .....be safe
SilverbackMel is offline   Reply With Quote
Old 10-01-2016, 10:23 PM   #3
SnP
One thing to think about. The King Dish is only one LNBF system. This means that it only picks up channels from one satellite. With two receivers, one may want to watch two different channels on two different satellites. No go with this dish. The Winegard Traveler 1000 allows for watching different channels off of any satellite at the same time. A little more expensive, but more functional. We are opting to not order the King Dish and have our ordering dealer install the Traveler 1000.
Steve and Paula, Tiki and Keyla, RIP Chance
2015 Ford F-350 Platinum DRW
2018 Cedar Creek Champagne 38EL
Camped - 2014-47, 2015-104, 2016-100, 2017-63
SnP is offline   Reply With Quote
Old 10-01-2016, 10:23 PM   #4
rattleNsmoke's Avatar
Youtube is your best friend. Personally, I'd do the work myself but then again I know my limitations. Good luck with your decision.
1988 Harley Softail Custom "The Fireman"
rattleNsmoke is offline   Reply With Quote
Old 12-11-2016, 06:05 PM   #5
So I just received my king tailgate. But I'm not sure what outfits to use on my 2017 Columbus rb
mharlow is offline   Reply With Quote
Old 12-12-2016, 08:13 AM   #6
DKRITTER's Avatar
An alternative would be the Trav'ler it is a Dish 1000 receiver and will receive all three satellites at once.
We had the X2 and it worked ok but upgraded to the Trav'ler and now when we do extended trips we just take our Hopper with us.
2015 Ford F350 CC SRW LB 4X4
2016 Cedar Creek 36CKTS (My Last FR Product)
20,000 LB Reese GooseBox Hitch
DKRITTER is offline   Reply With Quote
Old 12-12-2016, 08:40 AM   #7
The only problem with having a permanent roof mount is you'll need to choose sites carefully. If you go to places totally wooded it's next to impossible. When you have a portable such as a Tailgator, or better yet a tripod mounted 1000.2 or 1000.4 dish, you can most times find a hole through the trees even if you need to run 200' of coax. Its a little bit hard to position an entire RV to get line of site in the woods.
Mr Havercamp is offline   Reply With Quote
Old 12-12-2016, 06:25 PM   #8
When I book a campground site the first thing I ask for is a site without trees.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 12-16-2016, 12:03 AM   #9
I'm fabricating a mount for my tailgater that will use my flagpole mount on the rear ladder. This will get it off the ground. If the trees are in the way I can still set it out as a portable. The mount I'm building is a copy of one I found on the internet, I will remove my Tailgater for travel. I feel this will be the best of both worlds..
2015 Chev Silverado 3500 dually D/A
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
Old 12-16-2016, 12:05 AM   #10
The new Tailgater is now set up to enable the use of two seperate receivers.
