Old 05-30-2012, 09:19 PM   #1
King Pin Box Movement, Lippert Frame
We purchased a 2009 Silverback, model 34WBH, in March 2010, and have used it about 25 times since. After a wonderful trip over Memorial Day weekend, we returned home to find extensive damage to the bedroom ceiling, in the front of the camper. Upon looking deeper, we found that the king pin box has so much movement in it, that when pushed up on, the floor of the closet in the nose of the camper moves, about 3 inches. So, we immediately "googled" celing damage due to king pin box movement and found many comments about Lippert frames being very defective in many ways. (As our camper has "Lippert" stamped ALL over the entire hitch!)
We have called the dealer that we purchased the camper from, with no response yet, after explaining to them what we have found out about the frames having problems, etc. We are certain that we can repair the camper, to a very costly and time consuming chore, but are very hung up on the fact that Lippert knows something is "wrong" yet won't stand behind any defects.
Does anyone have any suggestions?
the4browns is offline   Reply With Quote
Old 05-30-2012, 09:25 PM   #2
TURBS's Avatar
WELCOME to the forum !
yeah this just stinks to high heaven !
Although I cannot offer much advice I can offer to take good notes on your all communication from here on out .
good luck !
Old 05-30-2012, 09:33 PM   #3
It does stink...it is heartbreaking to my little boys who love camping.....! Thanks for the advice to keep notes! (we just started a little notebook today!)
The problem is though, Lippert makes every camper frame but Jayco's; and there are many different manufactors which are having problems.
I wish it would go away, I want to continue my family's summer camping.
Any suggestions would be so helpful!
Old 05-30-2012, 10:11 PM   #4
DDC
DDC's Avatar
Call your state DOT and let them come and see it, Lippert is making there frames to be used on the highways so they should be able to stand up to what is considered normal use, the governing DOT will follow up but only if they get complaints. Good luck.
DDC is offline   Reply With Quote
Old 05-30-2012, 10:33 PM   #5
Yes, it sounds like you are another victim of Lippert's weak frames.
The main support beam across the front has probably broken.
I would also urge you to make a formal complaint to the proper government safety office, and send a cc to Lippert.
This has got to stop.
DonG is offline   Reply With Quote
Old 06-04-2012, 05:29 PM   #6
5th Wheel
2010 Cedar Creek
Silverback 29RE
Purchased brand new in July 2010
Used our 5th wheel locally, a trip to Durango, CO & trip to Pigeon Forge, TN.
The trip out to Pigeon Forge, TN stopped for the night and noticed a gap in the uderbelly where the front cap is attached with screws and caulked to the metal trim piece. Gap was 3/4-1" open from pin box around to the side of the underbelly.
When we arrived at the campground in PF and I started lowering the landing legs and removing the trailer weight off the pin box the gap closed up tight?
To make a long story short when I got back home from our trip contacted the Dealer Service Manager and told him what was going on. Of course my 5th wheel warranty had expired but after sending him pictures and many emails and phone calls with the Dealer, Forest River & Lipert Frames. FR/LF had my5th wheel transported back to the Cedar Creek factory to have the frame repaired and beefed up. Frame was flexing and plan is to remove cap and reweld and plate frame back up to the closet area in the bedroom, won't be getting trailer back until fisrt of march.
Sounds like the same issue I had with my Silverback. I would suggest contacting Forest River and ask to be put in contact with FR rep Kevin Caudill.
ryoucrazey is offline   Reply With Quote
Old 07-25-2012, 12:43 PM   #7
Old Member
mikey's Avatar
Send a message via Skype™ to mikey
As with all things Lippert . . .
As with all things Lippert, we as consumers should understand that Drew Industries/Lippert will not do the right thing and correct these types of problems. They will instead wait until an ugly raises it head, stall & stonewall the consumer, then eventually deal with that particular problem while hoping for the best with all other units on the road that have the same potential problem.. I would suggest contacting your state DOT and National Highway Safety Administration to make them aware of the long history of problems with all things Lippert!
My personal experience, Failed Lippert chassis, split I beam web above spring hangar caused axle to shift. Lippert initial response, my fault, then miraculously a service bulletin ( 4 years old) appears from Lippert that fully addressed problem. This same SB is used for present day failures by Lippert . . . case in point, they have never corrected the cause of the original failure!
Wish there were some alternative to Lippert Components Inc.
I apologise for my rant but when will this stop, after someone is killed or severely injured due to a Lippert failure?
Travel safe, keep vigelence on maintenance and enjoy your journeys.
Drivin, Miss Daisey & the boss, Toppi
2018 Berkshire XL40B-380, SFE=244
mikey is offline   Reply With Quote
Old 07-25-2012, 01:05 PM   #8
wyo700's Avatar
I am sure am reading a lot on these lippert frames on the 5th wheels failing. I sure hope my toy hauler that is a bumper pull doesn't start this. I have been keeping a close eye on it.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 07-25-2012, 02:18 PM   #9
Herk7769's Avatar
Mike,
Any chance you can post that Service Bulletin?
Lou
HAM CALLSIGN - KC3FFW
Old 07-25-2012, 03:20 PM   #10
Old Member
mikey's Avatar
Re: King Pin Box Movement, Lippert Frame
herk7769
Lou,
I'll look into our files when I get home tonight and post it then.
Mike
Old 07-25-2012, 04:27 PM   #11
Hob
My straight pull did the same thing with breaking cross braces. I tried another straight pull on a trade in. I lucked out and found a Dexter frame on a V-lite this time. Trailer was a 2011 the dealer couldn't sell. Perfect for me and the wife. I hope Lippert buying them after this trailer was built didn't rub off of this Dexter frame.
Hob is offline   Reply With Quote
Old 07-28-2012, 10:14 PM   #12
2010 Silverback 33RL
*Exact* same symptoms
They tell me it is safe to drive while they figure out if it's the frame or the body....
Sounds like I need to give these guys a call
Originally Posted by ryoucrazey View Post
5th Wheel
2010 Cedar Creek
Silverback 29RE
Keith & Liz
2010 SilverBack 33L
2009 F-250
kablair is offline   Reply With Quote
Old 07-28-2012, 10:35 PM   #13
Old Member
mikey's Avatar
If you pull the trailer you might be letting them off the hook by giving them the "you knew about the damage and continued. . . . so therefore its your fault"
I'm just saying. . . .
Old 07-29-2012, 07:32 AM   #14
DDC
DDC's Avatar
I'd still be contacting the D.O.T. in your State, they appear to be producing an unsafe product and only doing repairs when forced to, instead on doing a voluntary re-call to make sure their faulty product does not kill someone, once the State gets enough complaints it will order a re-call.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
Old 07-29-2012, 08:46 AM   #15
jimh's Avatar
[QUOTE=mikey;227624]
same problem. used that fix also.
for buliten
see post #16 under cardinal. Leaf spring hangers
jimh is offline   Reply With Quote
Old 07-31-2012, 05:27 PM   #16
Old Member
mikey's Avatar
Originally Posted by herk7769 View Post
Mike,
Lou
Lou,
Like old military records, this one (Lippert SB) too has found a hidey hole that might take some time to locate. I am looking, diligently!
In the mean time, I spoke with an official with the DOTs Motor Carrier Safety Division, who recommended a couple of things:
1) date time stamp all photos makes them evidence vice keep sakes.
2) Contact your state Atty Gen, BBB as well as Home | National Highway Traffic Safety Administration (NHTSA).
3) Also, provide copies of your complaint to the Consumer Affairs Division, Product Safety Commission.
Hopefully, these things should bring the Calvary in to help the manufacture figure out the right thing to do.
I am also inspecting my trailer after each trip so that nothing sneaks up on us. I saw a fiber optic camera on sale at the Nashville Camping World and wish now that I had bought it. Never fear I am looking for one as we speak.
Old 07-31-2012, 05:33 PM   #17
Iggy's Avatar
Just Google Lippert Kingpin Box damage and look what I found
RV.Net Open Roads Forum: Fifth-Wheels: Warning Lippert kingpin frame BROKE
http://forums.woodalls.com/index.cfm...g/25532588.cfm
Here is link to our forum that had a similiar problem
Cracks in 5th wheel pin box to frame
See page 2 for his pictures
2012 Georgetown XL - 378TS 73K miles
Ret. USAF Vietnam, '68 - '89
Iggy is online now   Reply With Quote
Old 07-31-2012, 05:42 PM   #18
Old Member
mikey's Avatar
. . .as a caviat to my post above: I relocated my pantry in order to better balance the weight, & I also drain the water heater tank (12 gal) before each long pull which eliminates about 100 lbs of needless weight, I only fill 5-6 gallons in the fresh water (1-2 minutes with the new type fill system on my trailer). Just enough for those emergency "P" breaks. Whatever I can load onto the TV, further reduces the trail weight (either pin or axle weight). Of course I have to keep an eye on things like TV GVW, Hitch Weight, etc. But, just like with airplanes, if you pay close attention to the little things, they won't be nearly so big when they blow up in your face......
Be ever vigilant, for Murphy is always lurking to lend a hand. . . . .
Old 07-31-2012, 05:48 PM   #19
Old Member
mikey's Avatar
Iggy, I just looked at the attachment. The SB is the same as I remember it from my Lippert failure.
A word of advise: Anyone who hasn't used dye penetrant before, pick up a kit and learn how to use it, especially if you own a Lippert Component chassis . . . (80% market share. . . go figure)
Old 07-31-2012, 06:49 PM   #20
"dye penetrant"
Mikey, is that something you spray on and it shows where the cracks are?
bakken is offline   Reply With Quote
