Old 07-06-2019, 01:19 PM   #1
King pin support? TPM system?
I am new to RVing and just bought a 2016 Cedar Creek 34RE 5th wheel. I have two questions - we are going to go on our first trip soon and am wondering if a king-pin stabilizer is needed and also what is the best tire pressure monitoring system recommended? I don't have a huge budget so am looking for inexpensive solutions.
rrolphe is offline   Reply With Quote
Old 07-06-2019, 01:24 PM   #2
Iwannacamp's Avatar
I donít have/never have had a king pin support. Most people donít use them. I do have JT Strongarms and Xchocks and step stabilizers. They all help.
I have a TST RV507 tpms when I researched I decided it was the best option.
Overall I would skip the pin stabilizer and add that money to the TPM.
2017 Puma 297RLSS
Old 07-06-2019, 02:45 PM   #3
DDC
DDC's Avatar
You donít need pin support, Iím assuming you have six point levelling system.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 07-06-2019, 03:39 PM   #4
SilhouettePenny's Avatar
DDC is correct, if you have the level up system then you should be very stable without pin support. We don't even use wheel chocks and we're rock solid after deploying the hydraulic jacks.
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 07-06-2019, 03:52 PM   #5
clr
I have a TST 507 tire monitoring system, and have used it now for about 3 years. It is a great system with great customer support, I would recommend.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 07-06-2019, 03:55 PM   #6
Gumpster808's Avatar
Another TST 507 TPMS user here. Works great and no issues with the system.
Got hot one day first season and since I went ultra conservative on the high pressure setting it went off. Will definitely get your attention. Upped it another 5% still in recommended range and no alarms since.
The new color monitor is much easier to see over the older black and white one also. New one has multiple trailers you can select as well in case you need that.
Lynn & Dennis
Nights Camped 2017 - 35 / 2018 - 15
2014 3051S - First RV for us
2018 Hyundai Elantra Sport Toad
2015 Harley CVO (retirement bike )
2015 Challenger ( Wife's Toy)
Gumpster808 is offline   Reply With Quote
Old 07-06-2019, 04:15 PM   #7
Oaklevel's Avatar
Where we camp most people use the king pin support, but we tried it but were not impressed.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 07-06-2019, 04:40 PM   #8
Thank you to all for your quick replies. I will forego the king-pin stabilizer and have ordered the TST 507 TPMS. It will be here before I leave on my trip
Old 07-06-2019, 04:44 PM   #9
clr
Thanks for coming back and letting us know your decisions.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
Old 07-07-2019, 01:49 PM   #10
I bought a 5th wheel stabilizer when I was a newbie. Carried it around for 6 months, used it twice. It's been in the barn for years. If you really want one I can give you a good deal. TPM is probably a good idea, but I don't use one.
DrLewie
Flemington, NJ
Former: 2007 Cardinal 30W LE
Now:2018 Arctic Fox 27-5L
2008 Ford F-250 Long Bed Diesel
Total of 28 Months on the Road Since 2008
DrLewie is offline   Reply With Quote
Old 07-07-2019, 05:29 PM   #11
I have never used a 5th wheel support on any of the 5ers I have had. I was told I needed one to support the neck to keep the stresses of people in the neck from damaging the trailer.......salesmen....trying make a few more dollars.
I have never used chokes or wheel locks. Once the landing gear is down in the front it's not going any where, unless you are on a very steep slope, then it would have to be slick to let it slide. Then I might put a block under a wheel.
Ben
gentle_1ben is offline   Reply With Quote
Old 07-07-2019, 09:31 PM   #12
Tundra 2014
TST
X4 on the TST 507. I added the chrome stem covers to my rubber valve stems on cap style sensors.
Tundra 2014 is offline   Reply With Quote
Old 07-07-2019, 09:36 PM   #13
TPMS for 3-4 years and very pleased.
Background: I have the 29IK and have had tire drop-out once in awhile.
I have tried the long antenna and the repeater and still once in awhile a wheel pressure will alarm.
I've tried changing batteries and sensors but the same wheel always seems to have weak signal.
My last trip however I separated systems and put my Furrion camera monitor close to the bottom of the windshield. I was using the TPMS long wire antenna and installed it so it was centered in the rear sliding window hanging from a cotton string. I only had to reinitialize the TPMS twice in 8 hours so I'm making positive progress.
Long story but just wanted to make sure you don't get discouraged initially if at first you have wheel drop-out alarms from the TPMS. It is a definite benefit to have one to monitor tire pressure and temperature.
PM me anytime if you need help diagnosing an issue.
Lvn2tvl is offline   Reply With Quote
Old 07-08-2019, 07:14 AM   #14
I highly recommend a TPMS for anyone that hauls a trailer and especially for those with heavy RVs.
We use the PressurePro TPMS for many, many years. System monitors high and low pressures, temperature and cross axle measurements. Since we do a lot of hauling at night, gives great peace of mind.
jd4010 is offline   Reply With Quote
Old 07-14-2019, 01:32 PM   #15
SlowrideHD's Avatar
I like our king pin tripod but I don't pull it our unless we are going to be set up for a week or more. It does help stabilize everything in my opinion. We have a Splendide washer/dryer in our bedroom closet and it really shakes things unless the tripod is set up.
I use an EezTire tpms so that is the only model I can speak to. It works great and has saved me from body damage on two occasions when the oem tires went through a sudden loss of air pressure.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
SlowrideHD is offline   Reply With Quote
Old 07-14-2019, 06:04 PM   #16
Thanks to everyone for sharing. I purchased and installed the ST 507 TPMS. Completed all the setup (excluding the repeater) and now it looks like I will need to install the repeater as well since the monitor doesn't connect unless I'm sitting with it inside at the table.
Old 07-15-2019, 02:50 PM   #17
I never had much luck with my TST tpms. Dropped out or wouldn't work at all. Sent it back several times, finally gave up. Wasn't worth the headache for me. Buy good tires, watch the inflation and look them over at rest stops.
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
Old 07-15-2019, 06:22 PM   #18
I stuck my repeater on the shelf in my battery compartment of my 36CK2. Added fork terminals and wingnuts to connect to the batteries. Monitor picks up signal pretty well.
2018 Cedar Creek 36CK2 (40.5ft)
TST Cap System (Tire Monitoring)
2015 Chevy 2500HD Crew Cab 4X4 SRW Duramax
Demco AutoSlide 18k
GMRCK25D - Rear Axle Timbren SES Suspension Upgrade
LittleBill is offline   Reply With Quote
Old 07-15-2019, 06:29 PM   #19
I got the color monitor with my TPMS thinking it would be better. But have found it quite difficult to read as the readings are a dark blue on a black background. I'm thinking now that the white readings with a black background would have be much easier to read in bright daylight.
Demco AutoSlide 18k
