Old 09-06-2016, 10:58 PM   #1
edt
Kitchen
Low water flow on stream good flow when on shower strainer is not stopped up is there a water restriction device this is the tall kitchen facuet
North Ga
2015 40' cls
Never to be moved
edt is offline   Reply With Quote
Old 09-07-2016, 10:24 AM   #2
Head Rambler
Originally Posted by edt View Post
Low water flow on stream, good flow when on shower. Strainer is not stopped up. Is there a water restriction device? This is the tall kitchen facuet
(Added some punctuation so I could better understand the problem. Hope I got it right.
There is a restrictor in the faucet. It should be in the aerator in the end of the spout. Unscrew it and clean it out. You may want to take a few pictures as you disassemble it, because it can be a bit of a pain to figure out how it goes back together. Of course you could always just leave it out.
Post a picture of the faucet and I can probably tell you exactly where it is.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 09-07-2016, 12:54 PM   #3
markfromark's Avatar
Check under the sink. The weight holding down the hose had the hose kinked in certain positions. I adjusted the weight and it solved the poor flow problem. If this makes no sense, PM me and I'll do a better job of explaining.
Mark and Dianna
along with memories of Pepper and Gracie
2016 CC Silverback 33IK
2015 Ram 3500 DRW
markfromark is offline   Reply With Quote
Old 09-07-2016, 01:03 PM   #4
edt
Kitchen Facuit
here are pictures
North Ga
2015 40' cls
Never to be moved
Old 09-07-2016, 01:09 PM   #5
edt
kitchen facuet
Think found how to send pictures
ID:	119654   Click image for larger version
North Ga
2015 40' cls
Never to be moved
Old 09-07-2016, 01:27 PM   #6
Head Rambler
The flow restrictor is that solid looking white piece on the right of the top pics. Personally I'd just leave it out and put the rest of it back together.
It's hard to tell from the pictures, but it should have a small hole or series of holes in it.
Gotta go campin!
