Old 07-13-2019, 07:09 PM   #1
Kitchen faucet leaks at connection
How do you get the faucet out? MAJOR leak at faucet connection. Hoses are ok but somewhere after hose connection to faucet fitting major leak. Need faucet out to see problem. THanks, Don
Cedar Creek 2018 38FBD
todalake is offline   Reply With Quote
Old 07-13-2019, 07:23 PM   #2
NMWildcat's Avatar
Just Google "how to replace RV faucet" and you find all kinds of videos and instructions with pics like this one.
https://www.google.com/url?sa=t&sour...uW-J6IUw0smY96
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
Old 07-13-2019, 08:40 PM   #3
Found problem, copper tubing broke. Fairly easy fix but I'm big guy and don't have right tools or small enough to get to it. I had replaced faucet on previous trailer. Will get new faucet Monday and get replaced Tuesday. How can tubing break sitting there, trailer hasn't been moved since sit up by dealer a year ago?
Old 07-13-2019, 09:07 PM   #4
NMWildcat's Avatar
Glad you found the problem!
Usually copper tubing fails during a freeze. Surprised there is copper tubing near the faucet in your RV.
Old 07-14-2019, 09:15 AM   #5
It was winterized. No problem for a month. There is a small brass ring around the break. It broke right at that ring. Will take a picture and post later. Crimped tube to shut water leak off and still use rest of water system for now.
Old 07-16-2019, 08:13 PM   #6
I had the same issue with a replacement bathroom faucet. It broke at the same spot even though the rig was winterized. My problem arose from two things:
1. Winterizing was done by blowing out the plumbing system with compressed air.
2. A few drops of water were left in the faucet which dropped back to the fitting then froze.
Unfortunately, the hose could not be replaced because it's a nonstandard fitting. I ended up replacing the entire faucet to get a replacement hose.
Phil
pmsherman is offline   Reply With Quote
Old 07-16-2019, 09:05 PM   #7
Many of the 'tall' type kitchen faucets have small copper feed tubes within the base which feed the spout.
I'm sure there isn't copper plumbing TO the faucet unless someone modified it.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 07-16-2019, 09:37 PM   #8
RV repair guy said that when factory tightened the fitting, don't use 2 wrenches and twisted copper tube up inside faucet. Another fitting on faucet wasn't even finger tight. Winterized by dealer, both blow air out first and then pump the pink winterize fluid thru all lines and faucets.
faucet, leak
